Results 1 to 10 of 13
- Sep 2006
- 14
September 20th, 2007 11:38 AM #1Mga guru
Help naman po. My car is a 98 lancer glxi na matic. The other day, bigla na lang ayaw mag start ng auto, naging erratic yung mga ilaw sa gauge so akala ko battery problem (baka loose terminals kasi bago lang ang batt)
Ni-series ko sya sa isang kotse pa at gumana naman. Pinaandar ko for about 30 minutes at baka kailangan lang magkarga nung batt. Nung patayin ko na at try start ulit, ayaw na, tapos nag re-reset na yung mga electrical like yung relo, radyo. After mga 15 minutes pa, try ko ulit i-series ayaw na. Pag try i-start, nagbablack out yung electricals ko (wala nang naka-ilaw sa gauge, ayaw na umandar ng ilaw, windows etc.). Try ko na rin palit ng battery (kinuha ko yung sa isang kotse ko pa na mas bago batt) just to make sure na hindi yung batt ang problema pero ayaw pa rin
Ano po kaya problema nito?
Tsikot Member Rank 4
- Jun 2006
- 2,605
September 20th, 2007 12:07 PM #2I'm no expert pero from what you stated, its obvious that its not the battery. I dont think its your alternator either since you cant start even with a new battery.
Hopefully, its just your main fuse. It should be located right on your battery's postive terminal or close to it. If its not there, check the engine fuse box. Wag naman sanag ECU.
- Nov 2006
- 299
September 20th, 2007 02:48 PM #3either you have a bad ignition switch,bad drive belt or bad alternator diode.
bad alternator diodes reduce alternator output current,output voltage,and may also ripple that can upset computer system operation.
- May 2005
- 66
September 26th, 2007 02:07 PM #4
April 12th, 2013 08:17 AM #5
mga sir anu kaya gagawin ko bigla nalang nawalan ng koreyente ung liteace ko ayaw narin mag start at wlang ilaw, posible kayang ung fuse lang ang sira may nakita kasi akong sirang fusible link(50 amps) ipa check ko paba sa mekaniko bago ko palitan ang fuse?
April 12th, 2013 08:35 AM #6
April 12th, 2013 08:46 AM #7
April 12th, 2013 10:33 AM #8
sabi mo sira na yung fuse di ba?
di papalitan mo rin yan, so bibili ka rin. pag kabit mo niyan at umistart yung oto, solb!
April 12th, 2013 11:06 AM #9
- Jul 2011
- 1,711
April 12th, 2013 11:36 AM #10
Choosing one would depend on your driving and parking conditions. Do you have your own garage =...
MG4 EV Standard vs BYD Atto 3 Dynamic vs Toyota...
