Results 11 to 16 of 16
June 21st, 2005 10:06 PM #11
yung dating thread dito sabi may nabibiling servo kit sa ATCO Mitsubishi Parts, taft ave corner edsa tel 8314177/8317321/8316365/8330859. di pa ko nakapunta dun, sinulat ko lang kasi yung info sa notes ko for the time na may need ako na mitsu parts. mura daw dun kesa sa mitsu casa.
look also for the thread about converting the servo to a mechanical type. hanap mo lang, use the search function.
- Jun 2005
- 68
June 21st, 2005 11:37 PM #12encountered the same with my galant, pa check mo ignition switch mo dre, yun ang culprit sa aking galant, kung anu-ano na pinalitan ko na pyesa, ignition lang pala. pinalitan ko lang ng bago, ayun at nawala na yung parang misfire na parang may kinakain na gears na tunog during ignition sa umaga.
- 3,754
June 22nd, 2005 10:37 PM #13Update ko lang.. I just cleaned the servo. medyo hindi na namamatay pag start ko ng aircon.. but the problem is during start nakaka takot hehehe parang missed fired talaga.. Pinalitan ko na din ng starter ganon pa din.. Pa check ko din nga ignition switch baka maluwag ang wire.
- 214
June 23rd, 2005 12:48 AM #14bka kelangan mu na mag palit ng servo-assembly, or try checking ur alternator..
- 3,754
June 23rd, 2005 07:55 PM #15falken
Mukhang Ok pa naman alternator since naka sound set up and hindi pa naman na drain ng bat. so OK pa siguro alternator yung start up lang talaga problema ko ngayon sobrang ingay parang yung sound ng gear na ayaw pumasok
- 3,754
June 27th, 2005 11:49 PM #16update ko lang I got a pinoy Mech. and he find out na ringer daw ang sira (di ko alam spell) basta someting in tranmission sad to say pinalitan namin ang tranmission OK na wala n yung sounds pag start.. sana wala ng kasunod hehehe
