Results 1 to 10 of 16
- 3,754
June 19th, 2005 06:54 PM #1I have changed the starter pero ganon pa rin maingay pag start parang missed fired I also changed the spark plug. what could be the problem. Ok naman on the long run pag start lang talaga ang problema. And one more thing is during idle pag on ko ng AC lalo na baba ang RPM.. damn engine ang laki ng idle control hindi ko ma baklas.. Any eclipse expert here.
June 20th, 2005 08:54 AM #2
what engine is it? better if u can get the engine code so ppl here can give u there suggestions.
June 20th, 2005 10:07 AM #4
1st gen o 2nd gen eclipse? either way 4g63t makina niyan.
try checking the servo or your high tension wires.
- 214
June 21st, 2005 12:26 AM #6i think servo yan, kasi bumababa yung rpm mo e, namamatayan kdn ba ng engine pag nag rev ka tpus bgla mu binitawan?
- 3,754
June 21st, 2005 07:17 PM #8Hindi pa ko nag papalit ng high tension wire wala kasi ako makita dito splitfire.. medyo mahirap mag hanap dito sa locations ko. its a Gen1 Eclipse non turbo. Medyo na mamatayan nga pag nag on ng AC kailangan habulin sa accelerator..
How can I repaired "servo" may kit ba na nabibili para sa reapair nito?
- 214
June 21st, 2005 07:59 PM #9may nabibiling repair kit, pero pag d nadala sa kit, kelangan mu na mag palit ng buong servo, i think nasa 13-15k yan, orig..
- 3,754
June 21st, 2005 09:02 PM #10Wow mahal din pala ang servo? salamat Falken... hirap kasi pamana lang sakin ang eclipse kaya pati mga sira na mana ko din hehehehe
Denali Lights, Dial Dim, & Soundbomb Review—Is It Worth The Premium? | Behind A Desk MotoDeal
Auxiliary Driving|Fog Lamps
