Results 1 to 16 of 16
    I have changed the starter pero ganon pa rin maingay pag start parang missed fired I also changed the spark plug. what could be the problem. Ok naman on the long run pag start lang talaga ang problema. And one more thing is during idle pag on ko ng AC lalo na baba ang RPM.. damn engine ang laki ng idle control hindi ko ma baklas.. Any eclipse expert here.
    what engine is it? better if u can get the engine code so ppl here can give u there suggestions.
    Dec 2003
    i think mitsu casas can help u
    1st gen o 2nd gen eclipse? either way 4g63t makina niyan.
    try checking the servo or your high tension wires.
    Jan 2004
    di kaya timing lang yan? or yung compressor kaya?
    i think servo yan, kasi bumababa yung rpm mo e, namamatayan kdn ba ng engine pag nag rev ka tpus bgla mu binitawan?
    Jun 2004
    hehe servo yan..
    dirty trottle bore or disconnect battery 1st..>>
    Hindi pa ko nag papalit ng high tension wire wala kasi ako makita dito splitfire.. medyo mahirap mag hanap dito sa locations ko. its a Gen1 Eclipse non turbo. Medyo na mamatayan nga pag nag on ng AC kailangan habulin sa accelerator..
    How can I repaired "servo" may kit ba na nabibili para sa reapair nito?
    may nabibiling repair kit, pero pag d nadala sa kit, kelangan mu na mag palit ng buong servo, i think nasa 13-15k yan, orig..
    Wow mahal din pala ang servo? salamat Falken... hirap kasi pamana lang sakin ang eclipse kaya pati mga sira na mana ko din hehehehe
    yung dating thread dito sabi may nabibiling servo kit sa ATCO Mitsubishi Parts, taft ave corner edsa tel 8314177/8317321/8316365/8330859. di pa ko nakapunta dun, sinulat ko lang kasi yung info sa notes ko for the time na may need ako na mitsu parts. mura daw dun kesa sa mitsu casa.
    look also for the thread about converting the servo to a mechanical type. hanap mo lang, use the search function.
    Jun 2005
    encountered the same with my galant, pa check mo ignition switch mo dre, yun ang culprit sa aking galant, kung anu-ano na pinalitan ko na pyesa, ignition lang pala. pinalitan ko lang ng bago, ayun at nawala na yung parang misfire na parang may kinakain na gears na tunog during ignition sa umaga.
    Update ko lang.. I just cleaned the servo. medyo hindi na namamatay pag start ko ng aircon.. but the problem is during start nakaka takot hehehe parang missed fired talaga.. Pinalitan ko na din ng starter ganon pa din.. Pa check ko din nga ignition switch baka maluwag ang wire.
    bka kelangan mu na mag palit ng servo-assembly, or try checking ur alternator..
    falken
    Mukhang Ok pa naman alternator since naka sound set up and hindi pa naman na drain ng bat. so OK pa siguro alternator yung start up lang talaga problema ko ngayon sobrang ingay parang yung sound ng gear na ayaw pumasok
    update ko lang I got a pinoy Mech. and he find out na ringer daw ang sira (di ko alam spell) basta someting in tranmission sad to say pinalitan namin ang tranmission OK na wala n yung sounds pag start.. sana wala ng kasunod hehehe
Help Mitsu Eclipse
