Results 31 to 40 of 41
October 8th, 2006 04:31 PM #31
di naman maapektohan ang engine mo pag bumitaw ang damper (vulcanize) ng cramkshaft pulley mo. your engine internals will still turn in sync with your valves, distributor, etc. the external components that will be be most likely be affected (affected ah, not damage) are, the alternator, PS pump, water pump and aircon compressor. you will notice that you battery indicator will lit up when in high rpm and turns off when idle, so as with your temp, high rpm higher temp.
October 8th, 2006 05:14 PM #32
tama po si sir afrasay wala po madamage un engine internal pag damper pulley lang nasira (bale 2 parts actually un damper; un outside nakalaminated rubber sa inside so wala po bearing na masisira) ang likely masira (madamay) ay un lang kasama sa drive belt
October 9th, 2006 04:53 AM #33
salamat po sa mga reply..hmm..hopefully bukas dadalhin ko na sa talyer..il post na lang later kung ano diagnost nung makaniko..
October 9th, 2006 05:10 AM #34
cge bro update mo kami ..actually ...kukumustahin ko na naunahan mo lang ako mag post..hehehe
October 14th, 2006 05:01 AM #35
update: dinala ko na kahapon yung car sa talyer..nung tngnan nung makaniko yung pulley nga ang sira..yung crankshaft pulley kasi hindi solid steel..merong rubber sa gitna..so yun ang napunit..dinala ko sa machine shop..pina allign at welding..so far ok naman na..
question: kailangan pa ba ipa timing or hindi na? kasi pagkasalpak nung mekaniko sa mga belt den pinaandar..ayun ok na daw..
October 14th, 2006 11:23 AM #37
hindi na kailangan i-timing yan...pero dapat hindi mo pina welding. you should have bought a good surplus or a new one. magkakaroon ng "shock" yun engine mo at may possibilidad na ma feel mo yun pag nag hard acceleration or pag nag open ang aircon compressor mo. could also cause a strain on your engine supports.
October 14th, 2006 11:25 AM #38
kaya may rubber siya para ma absorb niya yun biglaaan na increase in rpm.
October 14th, 2006 07:32 PM #40
ah ok..papalitan ko na lang den...hanap na lang ako ng surplus..tenks for the info mga sir..
Neither's mine. 3 yrs old and no issues whatsoever. Initial 2 PMS lang sa casa, the rest is OC...
Suzuki JIMNY [merged threads]
