Page 1 of 4 1234 LastLast
Results 1 to 20 of 70
    Feb 2005
    Hey guys, I've been usually driving in neutral for a year or so na when I get the right speed or when going downhill and I just want to know if it is a bad driving practice. I've read in the PinoyPC.net forums that it isn't good at all, I just want to ask your opinions on this.
    Do you guys do the same? Do you guys did it before? What are its negative effects? I heard it affects the carborator and a lot more other parts, like the breaks because of the stress it receives compared to engine breaking. I would say that one of my reasons of doing this rather than engine breaking is because it appears to be fuel saving. Please do post your experiences and observations.
    Sorry if I'm too n00bish, I'm just really curious on the facts regarding this. I kinda got used to it now and planning to stop doing the next time I drive. In my case, I've been getting the low idling because of carborator and fuel filter problems.
    Thanks!
    Dec 2003
    i only shift to neutral when im at a complete stop, otherwise i just keep it at D, 3 or 2 when on a steep incline.
    yep IIRC shifting to neutral while moving is bad for ur tranny.
  3. #3
    i dont know if its a myth,
    pero sabi nga its bad for a auto-tranny(all kinds) to cruise at neutral because of the wear..
    i'll just put it this way...yeah it will save fuel...but it will not save your brake pads, tranny mechanism...so in return, no savings..or worst..
    means that the amout you save on fuel cost may be used for the repairs...or worst, the fuel cost you save is not enough to pay the repair...
    unwise..
    if your car is brought new, then surely it has a owner's manual...just follow what is indicated there.or you can just search here at tsikot.. me thinks there's much knowledge you can dig here.
    hope this helps.
    Apr 2005
    "Kung M/T yung sasakyan mo, hindi. Kung A/T, oo." Based on another forum.
    Jun 2005
    Tanong ko lang po, if you are going downhill at naka 4th or 3rd gear ka pero di mo na inaapakan gas pedal, is it also considered cruising? ganoon kasi gawain ko pag nag drive ako
    Jul 2005
    This is what happens when a country doesn't issue a real driving test. The reasoning behind not cruising in neutral is that it is unsafe. Not that it will hurt your (MT) car; it won't, it's simply better driving to keep it in gear.
    Jun 2005
    Coasting in Neutral with an A/T is bad....if the engine is not running.
    Unlike an M/T, the A/T needs a pump to distribute the ATF all over the tranny. This pump derives its power directly from the torque converter's impeller, which in turn is connected to the flexplate and on to the engine's crankshaft. If the engine is off, the pump is also off, and the ATF can't get to certain moving parts causing premature wear and early failure.
    Jun 2005
    Quote Originally Posted by pal
    That's called engine braking or coasting in gear, depending on the rpm of the engine.
    If the engine is being used to slow down the vehicle, obviously it's called "engine braking"; but if the engine is merely pacing along with the slowing car, then it's more appropriately called "coasting".
    Jan 2004
    post ko lang po ang opinion ko i don't know for sure. pero ang alam ko, either M/T or A/T pag nag- neutral while cruising is bad. for one, you are compromising the traction of the vehicle. to make it simple, you are simply removing the force between the contact patch and pavement by putting the tranny in neutral while cruising, making the vehicle much lighter applying the mechanical advantage. besides, sino namang matinong driver ang gagawa nun?
    Jun 2005
    Cruising in neutral isn't really that bad unless unless you do it in an old technology vehicle with bad brakes. Most, if not all modern cars have brakes that are more than sufficient in stopping a car safely repeated from high speeds with little or no brake fade.
    Jan 2003
    cruising in neutral is not very bad but it does add to earlier wear of the breaks... engine breaking while braking is a safer option beacuse when you suddenly need to accelerate... like to avoid hitting something that split second of engaging the clutch and popping into gear can cause you that split second...
    but it really does save you gas... it's what Mr. Ramirez did to the jazz he drove for petron... neutral on downhills...kaya nya nakuha yung 1114kms on one tank...
    Feb 2005
    Ok. Well I'm using M/T and I really see how it saves much. But yeah, it does promote wearing of other parts a bit faster.
    Jun 2005
    You may save on fuel but you are compromising safety. What if your brakes malfunction?
    Jun 2005
    Quote Originally Posted by j_avonni
    That's a good point, especially for vehicles that do not have synchros or have malfunctioning transmissions.
    It happened in my town once, there was this guy (must not have had enough experience) who was asked to drive the dump truck parked outside the Town Hall. The truck was parked facing downhill on a road with a 30deg incline. He climbed the cabin, stepped on the clutch and let the truck roll in neutral with the engine off, thinking it wasn't that much of a deal to start the engine in neutral with the truck rolling.
    Turns out the truck had a problem starting. He starts using the brake, upon which he realizes the air tank had been bled empty. He figures he could "roll-start" the truck, so he tries to engage second. Too bad, the truck had no synchros, and all he got was the grinding sound of unmeshable cogs. He finally realized he should not let the speed build up some more so he musters all his courage and tries to do a 90deg turn at 40 kph at the next intersection. (He had passed 2 intersections already while trying to fight with the truck's controls, and the one coming up was the 2nd to the last intersection, whereupon he faced the prospect of ramming the 4-ton, all-steel truck, through a house at a good 50-60 kph.)
    Sad to say, all he could manage was a 60deg turn what with the steering's power assist off line. (I think that was pretty good, considering the unimaginable effort a truck's steering would have with the power-assist off. Must have been the adrenaline rush that gave hime the strength to execute that near-90 in less than 2 seconds.) The truck ditches, and plows through somebody's cement fence. Thankfully, nobody was hurt.
    Oct 2004
    yeah, cruising in neutral especially on downhill will save you fuel, but it is pretty unsafe since there will be less control for the drive wheels. Whenever you have the gear engaged, it provides you better ground traction.
    Jun 2005
    Quote Originally Posted by EssB
    If you know what you're doing, ie, know the dynamics involved, you can still do it pretty safely. But it's a generally good idea to be safe, especially if you're asked to drive an unfamilliar vehicle.
    Things to consider when deciding to freewheel downhill:
    1. Is the downhill too steep that it requires you to keep on applying light brake pressure just to maintain a safe speed?
    2. Is the vehicle carrying or towing close to max the payload capacity or the towing capacity?
    3. Can you be sure the vehicle's brakes are in good working condition, ie, does not grab, pull to one side, is not prone to brake fade, does not require pedal pumping, can retain hydraulic pressure for more than a minute, etc.?
    4. Does the engine idle steadily?
    If you drive the vehicle everyday, you should have a good idea of its general condition.
    Also one more thing to keep in mind is, if the engine dies for whatever reason, stop the vehicle on the side of the road immediately. Do not pump the pedal, just apply steady pressure to stop the vehicle smoothly and quickly. Only when you're stopped should you attempt to restart the vehicle. Restarting the engine while vehicle is in motion might be unsuccessful, all the while the vacuum in the brake booster might slowly be draining away, hence the importance of stopping immediately.
    May 2005
    In my opinion it's bad if you don't know how to.
    it won't break your car.... provided you make sure that revs are appropriately matched when you re-engage the gearbox, whether for manuals or automatics.
    i think the reason why it is not advisable to cruise in neutral is that you lose precious time in case of an emergency where you may need power instantly.
    Quote Originally Posted by impulzz
    cruising in neutral is not very bad but it does add to earlier wear of the brakes... engine braking while braking is a safer option beacuse when you suddenly need to accelerate... like to avoid hitting something that split second of engaging the clutch and popping into gear can cause you that split second...
    That Jazz was a CVT. If the idea that an A/T gets damaged while cruising in neutral is true, then Ramirez is not being a good example to driving your car. I know they're trying to maximize the fuel, but the whole thing is useless if it will wear out your vehicle more easily.
    Quote Originally Posted by mbt
    I agree. You have less control over the vehicle. AFAIK, its illegal in CA to cruise in neutral or most states prohibits this. I know, how are they going to know right? They will, when you get into an accident.
Cruising in Neutral: Bad?
