i recently bought a second hand local gen2 paj. Since maganda kung everything is new for record keeping purposes, ano kaya recommended specs nyo ng gear oil . Pakispecify naman ng preferred brand. Patulong naman mga bossing! :help!:
check the owners manual. the specs are there. as far as i can remember the required specs are:
GL4 rated
SAE 75-90
Hyphoid
i'll double check my owners manual and get back to you later.
most gasoline stations have SAE 90, GL4 gear oils. di lang yata hyphoid gear oil. for my rig i use mobil 1 fully synthetic SAE 75-90, Hyphoid, GL5 (or 6 yata) gear oil.
castrol also has a good gear oil - castrol hypoy (SAE 90, mineral, GL 5 (or 6). you can get this in most reputable car accessory shops. price is around P400/liter last time i checked.
Pwede DIY. I've tried it though preferable na may katulong ka para may tumitingin sa ilalim kung umaapaw na yung oil. Ako kasi tagahawak ng hose at tagasalin ng oil sa bandang itaas
Advisable din na medyo malaking hose ang gamitin kasi sa lapot ng oil (SAE 90) ang tagal bago bumaba. Maliit na hose kasi nagamit namin. Buti na lang mahaba ang pasensya nung nandun sa ilalim
