Results 11 to 20 of 39
September 29th, 2007 01:50 PM #11
maybe isa lang ang nagstuck. yung isang gulong e working pa. malamang stuck break nga yan dahil kakarelease mo lang ng handbreak. bubuksan yung brake drum mo nyan for sure. ordinary mechanic can handle it.
September 29th, 2007 01:53 PM #12
bro, baka natakot yun gulong sa avatar mo? hehehheehe joke lang...
September 29th, 2007 02:16 PM #13
ramdam ko isang gulong lang stuck e... sana maawa ung mekaniko sa avatar ko
Tsikot Member Rank 4
- Jun 2006
- 2,605
September 29th, 2007 07:55 PM #14Paayos mo agad and dont drive that car if possible. Your brakes are most likely stuck up. Your brakes will overheat and it will not take long before it starts to smell like burnt rubber. You will also lose brake pressure. Your brake pedal will sink and you will have to pump the brakes to get any resistance.
September 29th, 2007 08:39 PM #15
if my brakes are indeed stucked... are there any parts which needs to be replaced? I only drove for 200 meters.. binagalan ko rin ung takbo para di masyado uminit
September 30th, 2007 05:41 AM #16
Your piston brake caliper ay sira na kaya nag stucked up. You could buy a overhaul brake caliper kit usually spring and rubber gromet and rubber boot. Isang set yan for both axle. Madaling gawin yan basta bit mechanical person ka. Bumili ka narin ang bagong brake fluid mo to replace those old contaminated fluid in your brake system.
Tsikot Member Rank 5
- Nov 2003
- 3,849
September 30th, 2007 02:11 PM #17sa esi you have a drum at the back... could be a stuck shoe caused by kalawang if you passed by a flood. have it opened immediately and replace the necessary parts.
September 30th, 2007 10:00 PM #20
hinde kaya sir, matagal hinde nagamit yung oto na naiwan na naka handbrake? normally kung stuck up lang, pag pinilit mo i andar tutunog at maiikot mo ulit , pero kung maiikot then stuck ulet, pabuksan mo na para sigurado, baka kinalawang sa mga pagbahabaha.
Hello po, new lang po me sa Car Industry Me and my Dad purchased a 2nd hand po na toyota innova...
