mga bro ask ko lang po...meron lumalabas na tubig sa tambutso ko pag ni rebolusyon konti lang nman. evry morning na i start ko sya meron lumalabas. san po kya problem neto?
sir ghosthunter? what do u mean nothing to woory about? normal po b iyon?
Yup... normal lang yan. Happens to everyone.
san ba galing tubig nun ? sa radiator or sa makina itself? if sa makina meaning ba nun humahalo sa langis? muka nmang hindi nag mix ung tubig sa oil since pag chk ko ung langis wla nman sign ng water.
tnx mga bro
How much water? just drops? If its just drops then its nothing more than the moisture of the cat getting released.
yup just drop I think 5-8 drops. everytime I stary my engine? Is it normal?
May connection kya to pag nag tumataas temp nya pag naka aircon?
Yes, normal lang yun hehe...
When you drive your car and shut it off at night, the pipes (from manifold to the exhaust tip) are warm to hot, since malamig ang panahon pag dating sa madaling araw, the external temp is cool while the inner is still warm, so nagfoform ng condensation sa loob, usually sa muffler/tailpipe area na since dun pinaka malamig.
When you start sa AM, the heat will turn the small amount of water in to steam. Those water accumulation that sits near the tailpipe doesn't get that much heat sa pipe so it spews out when you rev.
Kung parang hose ang buga, ibang usapan na yun hehehe.
correct normal po yan. nagworry din ako when i saw my tail pipe with moist. kasi before wala naman.
sabi ng suking mechanic it means healthy combustion.![]()
pa ride na din dito..
pano pala kung medyo madami tubig na lumalabas? ano kaya problem nun? pag cold start eh madami talaga pero pag mainit na makina eh may konti pa din
The water doesn't come from the catalytic converter or anywhere in the cooling system. Combustion produces water as a byproduct and hence, is normal when driving a vehicle. This is even more visible in the morning when water has condensed overnight and once the vehicle is started, heats up a bit and drips out the tailpipe.
2 atoms of hydrogen (from fuel) plus 1 atom of oxygen (catalytic conver) =H2O (water), tubig visible pa at cold start pag mainit na vaporized na kaya wala ng makita
normal lang po yan pag malamig pa ang engine... that's just because of condensation....![]()
