good day guys.
help naman po sa problem na to.ano po kaya possible cause and ano dapat gawin? ayaw mamatay ng makina kahit naka turn off na ung ignition switch.
TIA!
good day guys.
TIA!
1st gear mo tapos release mo yun clutch para magstall ang engine patay engine mo. ganyan din sakin dati yun may alarm siya.
How'd you turn it off to get on the net? Discon sa battery?
Malamang ignition switch ang problem... you might be able to find surplus assemblies in Banaue, pero I don't know how much.
forza1:
related ba sa alarm ung problem nung sayo sir?
niky:
una disconnect ko sa batt pero andar pa din. cguro dahil sa alternator. then after 2-3 mins kusa lng namatay ung makina.
Shock... big hassle yun.
Sa mga alarm, minsan may sariling cut-off at engine-start feature na umiikot sa ignition switch. Kung may aftermarket alarm ka, baka ito yung problema.
May kakilala akong killer, sureball yun, malinis tumira. Walang sabit at walang iniiwang ebidensya.![]()
sana masolve nyo to, i have a friend kasi with the same problem, he has a daihatsu charade, it wont shutdown even with the ignition off, normally it happens pag na traffic sya, he has to run the car fast first to cool the engine down a little bit tas dun lang mamatay. he even had the car top-overhauled pero no effect, still wont shutdown. kindly post po pag na solve nyo ty ty
Maaaring masyadong naka advance yung timming kaya ayaw mamatay ganyan kasi pag sobrang advance. Pag switch off mo ba pumapalyapalya yung engine?
pag overly advance yung timing ng engine ay magdedesieling sya pero hindi ibig sabihin na di na nammatay(like diesel engine even if the key is off the engine still running but its just for a while then suddenly dies) ang problema ng kotse nyo ay maaaring isa sa mga ito,,,ignition switch,it might be corroded or loose,,,ignition relay,could be stuck closed.
i also experienced this with my father-in-law SUV, ang main cause ay iyung aftermarket na alarm which have an automatic switch-on feature of the engine
nangyayari sa kin yan ngayon sa pajero ko. akala ko may problema na, turbo timer lang pala, after 1 minute pa sya namamatay![]()
good day guys!
sorry ngayon lang ako nag-reply busy kasi itong week na to.
ok na yung sentra ko. sobrang advance pala ung timing kaya ayaw mamatay ng makina.
ang ginagawa ko nung ayaw mamatay disconect ko dun sa ignition coil kaya lng hassle talaga mag alis nun.hehehe. buti ok na sya.
thanks sa mga advice nyo.sa susunod uli!
Madalas yan kasi ang problema ng mga Gasoline Engine buti nabalik na sa normal. :fly:
