Results 1 to 10 of 10
- Nov 2002
- 9
April 12th, 2005 07:39 PM #1Hi guys, patulong naman. I have a problem sa Car ko (Lancer EL '94). Sa umaga madaling magstart (one click lang) yet pag itinakbo mo na for an hour or pag-uminit na ang engine, once pinatay mo and have it rest for 15mins or more, hard starting na. Kailangan sagad ang tapak sa rev para madaling umandar. Ano kaya problem nito? thanks
- Nov 2002
- 9
April 12th, 2005 09:10 PM #3Sige po.. patune-up ko na lang uli. Have just tuned up it last January lang kasi. Thanks
April 12th, 2005 10:56 PM #4
baka malapit nang masira yung ignition coil? ganyan din yung symptom nung box type galant namin dati e, pinalitan lang yung ignition coil at naging ok na.
April 13th, 2005 12:40 AM #5
ignition coil yan sir...ayaw magstart ulit kapag mainit na yung engine kailangan palimigin muna saka sya magstart ulit. nangyari na po sa kin yan eh
April 13th, 2005 02:58 AM #6
tama sila, try mo ito. When the car is all warmed up, try touching the ignition coil, it should be just warm to the touch. if not at pag sobrang init try to put wet "basahan" over it to cool it down. mag start ulit agad car mo when it cools down.
Driver/PasaHERO
- 1,310
April 13th, 2005 11:58 AM #8kung walang problema sa starting pag morning (cold engine) tapos after an hour of driving e ayaw na mag start, ignition coil nga yan, nde magi start hangga't mainit sya masyado, gawin mo sabi ni afrasay to check kung ignition coil nga problem
- Nov 2002
- 9
April 13th, 2005 07:02 PM #9Thanks for all the replies. Cge i'll check my ignition coil at baka nga malapit nang masira. Again thanks for the help
April 13th, 2005 07:19 PM #10
may natutunan na naman ako! hot ignition coil results to hard starting, dami talaga natututunan todits. aprub!
