Hi guys, patulong naman. I have a problem sa Car ko (Lancer EL '94). Sa umaga madaling magstart (one click lang) yet pag itinakbo mo na for an hour or pag-uminit na ang engine, once pinatay mo and have it rest for 15mins or more, hard starting na. Kailangan sagad ang tapak sa rev para madaling umandar. Ano kaya problem nito? thanks
baka malapit nang masira yung ignition coil? ganyan din yung symptom nung box type galant namin dati e, pinalitan lang yung ignition coil at naging ok na.
tama sila, try mo ito. When the car is all warmed up, try touching the ignition coil, it should be just warm to the touch. if not at pag sobrang init try to put wet "basahan" over it to cool it down. mag start ulit agad car mo when it cools down.
kung walang problema sa starting pag morning (cold engine) tapos after an hour of driving e ayaw na mag start, ignition coil nga yan, nde magi start hangga't mainit sya masyado, gawin mo sabi ni afrasay to check kung ignition coil nga problem
