Results 1 to 10 of 10
    Hi guys, patulong naman. I have a problem sa Car ko (Lancer EL '94). Sa umaga madaling magstart (one click lang) yet pag itinakbo mo na for an hour or pag-uminit na ang engine, once pinatay mo and have it rest for 15mins or more, hard starting na. Kailangan sagad ang tapak sa rev para madaling umandar. Ano kaya problem nito? thanks
    Jan 2003
    Pa-tune up mo na lang po yan. Ganyan dati nangyari sa galant ko.
    Sige po.. patune-up ko na lang uli. Have just tuned up it last January lang kasi. Thanks
    Mar 2003
    baka malapit nang masira yung ignition coil? ganyan din yung symptom nung box type galant namin dati e, pinalitan lang yung ignition coil at naging ok na.
    May 2004
    ignition coil yan sir...ayaw magstart ulit kapag mainit na yung engine kailangan palimigin muna saka sya magstart ulit. nangyari na po sa kin yan eh
    tama sila, try mo ito. When the car is all warmed up, try touching the ignition coil, it should be just warm to the touch. if not at pag sobrang init try to put wet "basahan" over it to cool it down. mag start ulit agad car mo when it cools down.
    Mar 2005
    ditto on the ignition coil if it has one.
    kung walang problema sa starting pag morning (cold engine) tapos after an hour of driving e ayaw na mag start, ignition coil nga yan, nde magi start hangga't mainit sya masyado, gawin mo sabi ni afrasay to check kung ignition coil nga problem
    Thanks for all the replies. Cge i'll check my ignition coil at baka nga malapit nang masira. Again thanks for the help
    may natutunan na naman ako! hot ignition coil results to hard starting, dami talaga natututunan todits. aprub!
Hard Starting Lancer
