- Forums
- Discussions
- Events
- Community
April 15th, 2004 11:07 AM
here, this might help dude:
II. Engine rotates but will not start:
1. Fuel tank empty.
2. Battery discharged.
3. Battery terminal connections loose or corodded.
4. Leaking fuel injectors, faulty fuel pump, pressure regulator, etc.
5. Fuel not reaching fuel rail.
6. Ignition components damp or damaged.
7. Worn, faulty or incorrect gapped sparkplugs.
8. Broken, loose or disconnected wiring in the starting circuit.
9. Loose distributor is changing ignition timing.
10. Broken, loose or disconnected wires at the ignition coil.
III. Engine hard to start when cold:
1. Battery discharged or low.
2. Malfunctioning fuel system.
3. Injector(s) leaking.
4, Distributor rotor carbon tracked.
IV. Engine hard to start when hot:
1. Air filter clogged.
2. Fuel not reaching the fuel injection system.
3. Corodded battery connections, especially ground.
