Results 41 to 50 of 78
August 15th, 2005 02:16 PM #41
no its not.
under regular load even if you have an audio system you do not need a cap. You only need a cap for transient loads. the cap is hooked between a battery and amp, it doesn't affect any other electrical equipment other than what is hooked up to the cap.
grounding kits simply allows less resistance for the current to flow due to thicker gauges.
August 15th, 2005 02:27 PM #42Originally Posted by theveed
hmmm di ba po merong mga "voltage regulators" na you can buy daw that will stabilize the voltage daw po, is that different?
August 15th, 2005 02:57 PM #43
Your alternator should do that. Unless it's shot, you shouldn't have to worry about it.
August 15th, 2005 03:04 PM #44
yung 4 gauge wire....parehas po ba ng kapal ng red wire ng ampli yan?
August 15th, 2005 03:15 PM #45
Jeep: Amp wires can be anywhere between 0 gauge to 12 gauge, also, be wary of wires na gawa dito or china, the insulation may be very thick, but the actual copper wire is very thin.
August 15th, 2005 03:34 PM #46
Power Cable/Wires available in Raon are gauge 8. Deeco is selling gauge 12 speaker wires,these babies are thick * 70/meter medyo pricey.
August 16th, 2005 01:11 PM #47
huhuhu nagulo na hehehe :D
ano po maganda gauge para dito?
basta sabihin mo lang yung gauge sa mga electrical shops?
tnx
August 16th, 2005 01:30 PM #48
8 gauge will do, 4 gauge will be better. Hirap lang maghanap ng magandang 4 gauge wires dito, available yan sa mga automotive shops or electrical shops, preferably buy the 4 gauge power cables for audio.
August 17th, 2005 02:46 PM #49
may nakagawa na po ba para sa diesel? saan po grounding points ng diesel engines?
crosswind po...tnx ;)
August 17th, 2005 03:06 PM #50
Jeepcruizerph: Kahit anong oto, basta gumagamit ng battery at alternator hehe.
Daming issue ng SU7:grin:
Xiaomi E-Car
