Results 11 to 13 of 13
January 15th, 2004 09:33 PM #11
To prevent rust, wash the exhaust before using your vehicle. Do not wash it prior to storing your vehicle or parking it overnight.
You can also drill a small hole in the bottom of your muffler is you are concerned about water pooling inside.
January 15th, 2004 09:53 PM #12
tama si otep, rust will accumulate only if water stays in your muffler for a long periods of time. as soon as you use the vehicle, the heat of the exhaust is enough to dry the water left inside of it. be sure lang na naka incline ang ride mo in such a way na mas mataas ang engine mo bago bugahan. change your oil/filter/air filter too. Also check/clean the strainer sa fuel intake ng injection pump. yun van namin dati once a week lang ginagamit (weekend) every year magpapalit ng muffler
January 15th, 2004 10:48 PM #13
Yung mga JDM PAj ata stainless or aluminum yung exhaust system? Wala ako makita kalawang eh
Traffic!
