Results 11 to 19 of 19
Tsikot Member Rank 5
- Nov 2003
- 3,849
January 1st, 2007 10:59 AM #11if you replace the gear oil and adjust the clutch properly and may tunog pa then you have to replace the gear to stop it from crunching.
- Nov 2003
- 3,849
January 4th, 2007 01:19 AM #14
- Jan 2007
- 2
January 6th, 2007 05:11 AM #15similar problem din sa kotse ko,minsan ang hirap mag change gear tapos minsan ok naman,check ko yung fluid eh may laman naman,ano kaya problema nun?
- Nov 2003
- 3,849
January 10th, 2007 08:01 AM #16kahit may laman sya, kung luma parin it might be causing the problems.
January 11th, 2007 03:00 AM #18
A lot of you guys are missing out the transmission mounts... It's an old car and if the tranny mounts have never been replaced before, you have to... Worn tranny mounts causes the transmission to be unstable when the car is running; the engine causes the tranny to vibrate vigorously especially at idle, during inconsistent amount of power delivery, as well as everytime you compress and depress on the clutch pedal... Chances are the tranny itself isn't aligned, which makes it eventually hard to shift to a certain gear/s...
Also, have the gear oil replaced... there are debris that circulate all over your tranny as the fluid does, so get rid of them...
btw, you can check for gear oil leaks by looking underneath, check on the drain and filler holes, and little possibly on tranny ends...
Also, have the cables, hoses, brake master/slave cylinder, etc, checked by a reputable shop/mechanic...
February 8th, 2007 04:51 PM #19
Artpogi is right, consider mo yung mga suggestions niya. Yun ang mga possibilities na problem na sasakyan mo. Huwag ka kaagad pagagawa sa casa. Sa mekaniko mong suki kaya nia yan at alang computer analyzer na involve dian sa pagpapagawa nian. Ingat tayo mga tsikoters sa mga pambobola ng casa at ng ibang talyer na may magagandang puesto.
Post muna tayo sa tsikoters before pagawa para magkaroon tayo ng other options. Drive Safely.
Daming issue ng SU7:grin:
Xiaomi E-Car
