Bago lang ako dito at napapost ako dahil sa nagkamali ako ng paglagay ng gas sa sasakyan ko, imbis na Velocity na palagay ko unleaded. Ngayon pagtakbo ko ng sasakyan mga after 30 minutes biglang ayaw na magrespond ang gas pedal. Napatow pa ang sasakyan. BTW ang kotse ay Nissan Sentra na Automatic transmission
Ang unang tanong ko ay yun pagpalit ko ba ng gas ang dahilan sa pagsira ng kotse? Kung oo, kailangan ko bang ipadrain ang tank para maayos ito?
Is it the gas pedal that is not responding or the engine when you step on the gas pedal? If the all the electrical stuff work and you hear the fuel punp working but it won't start it could be a that the fuel filter is clogged up and needs to be changed. Do you run it a lot with low fuel? If so then the deposits in the bottom of the tank could have clogged the filters. My BMW did the same thing when it just died on the way home and wouldn't start but everything else worked.
