Results 31 to 40 of 48
November 4th, 2004 06:22 PM #31
hmm. i'm beginning to think na mas malamig nga operating temp ng diesel sa gas.. hehe.. when i had my MB gasser.. it never went down 90deg unless malamig panahon.. comparing my gasser sa diesel wagon ko.. the wagon is running at a cooler temp in all ocassions compared to my gasser.
November 4th, 2004 07:30 PM #33
bakit po sa inyo umaakyat baba...? yun rav namin, hindi ko pa nakitang nagbago ang normal running temp niya... forever nang nasa gitna talaga siya, umuulan, mainit, gabi, umaga kahit saan.. kahit almost hulday umaandar.
November 5th, 2004 11:03 AM #34
The engine coolant temp indicated on dash panel is a function also of the accuracy of the temp sensing unit. I replaced one for my ride as I'm seeing the temp way below the halfway mark on summer day (approx 1/4) which is very unusual. After I replaced it (P1K for pajero) its now a tad below halfway mark. Just make sure you are getting the correct read-out as this sensing unit is subject to wear and tear also, although I'm not sure if the indicated temp of deteriorating sensor is more inclined to report lower temp than higher temp.
November 9th, 2004 02:04 PM #35
don't compare the thermometers...they only show "relative temperature" readings.... even the same brands may have slight deviations.....
to get absolute temperature, you need a "true thermometer"....
November 9th, 2004 03:26 PM #36
my temp gauge is usually a little below the halfway mark and increases slightly after prolonged driving in hot weather.
Driver/PasaHERO
- 1,310
November 10th, 2004 06:34 PM #38
most newer cars dont have the "dynamic" temp gauge... kaya if your car is healthy.. it stays more or less around the half-way mark.
- Apr 2005
- 14
May 9th, 2005 02:08 AM #39mine is a bit below the middle. i'm on 70% prestone and 30 distilled water.
May 9th, 2005 04:05 AM #40
my temps have always been just below the halfway mark ... never seen it rise higher than that ...
