Results 1 to 2 of 2
- Nov 2003
- 98
May 1st, 2005 03:01 PM #1guys tulong naman o. out tamaraw fx (5k engine) wont start. the battery is ok and the headlights are functioning. checked all fuses (engine, ign, ...) all are ok. problem is that when i switched the ignition on at the acc postion stereo wont start as well as the lighter 12 v outlet. checked all fuses wala na mang blown. when i switch on the ignition, walang nangyayari. even the check oil light is out. even a slight crank, wala talaga.... ano po kaya prob dito? sana may maka tulong diyan. salamat in advance po. :D
Since you got this 2nd hand, its a good idea to change the drive belt (its cheap anyway). Also...
