Results 1 to 6 of 6
- Jan 2003
- 7
January 19th, 2004 09:56 AM #1Car is 92 Lancer GTI. Where can I buy cheap ECU (computer box) for my car? Recently had problem with the car, had it checked and found out that the ECU has burnt IC's. Kindly post the store names and contact nos. Thanks in advance.
Tsikot Member Rank 5
- Nov 2003
- 3,849
January 19th, 2004 11:26 AM #2you can go around sa banawe and look at the shops that have surplus engines. i'm sure mura lang yung box na hinahanap mo tyagain mo lang yung paghanap!
- Jan 2003
- 7
January 20th, 2004 09:59 AM #3nagtanong ako kahapon sa el dorado, 48k ang presyo ng brand new, 62k+ naman sa diamond motors. grabe presyo. baka may alam kayo dito sa bandang pasay, malapit kasi sa work ko.
January 20th, 2004 10:23 AM #4
Pre Sgot,
try scouting dyan banda sa may area ng Evangelista, yung mga shops dun na nagbebenta ng surplus engines.
January 20th, 2004 11:07 AM #5
sgot: Medyo common ang pagsira ng ECU ng GTi Lancer... You might want to have the ECU checked first, baka kaya repair... If i'm not mistaken, you can get a surplus ECU for a lancer under 8K sa banawe or evangelista...
Try clubmitsu for help... baka mas maraming makakatulong sayo
- Jan 2003
- 7
January 20th, 2004 01:18 PM #6actually napa-check na yung ecu sa isang shop, sabi nila busted daw yung 2 ic, saka yung isang diode (or resistor). yung board kasi, may sunog na part sa tapat ng isang pin nung isang ic. dinala naman ngayon sa isa pang nagre-repair, baka bukas ko pa makuha feedback nila. nakatawag na rin ako sa mit parts sa banawe, 16.5k, sa motorix banawe, 22k. laki diperensya ng presyo medyo nakakaduda kung bago o refurbished na ecu lang. try ko makahanap sa mga surplus shops.
Kwento ng katrabaho ko, meron daw sya officemate dati na Italiano na tinanong daw bakit...
Traffic!
