Results 1 to 10 of 13
- Nov 2002
- 29
November 2nd, 2002 11:27 AM #1Mga DIY na pare ko, Paano ba mag-adjust ng carburetor? Marami na akong napuntahan mga website about carb adj. pero parang iba-iba rin ang ang suggestions nila. Share nyo naman ang method ninyo. Thanks...
BANNED BANNED BANNED
- 3,790
November 5th, 2002 09:00 PM #2There is one I learned on carb adjustment...."IF IT AINT BROKE, DONT FIX"
Most often the problem is not the carb adjustment (nozzles and jet)...Usually its one of these:
1) Unlubricated pivots or springs - sol'n->spray liberal quantities of WD40
2) Unlubricated cable - sol'n ->pull out the cable from the cable housing and lubricate with grease and slide it back into the cable housing and reinstall.
3) Dirty carb nozzles - sol'n -> if you have money buy a canister of the carb cleaner and follow instructions of use. If you don't have money, brush the carb with fuel as solvent...do this while engine is running so you could "force" some air para mahigop ang mga dumi na nadissolve.
4) Dirty fuel filter - sol'n -> replace lang ang option.
5) Baradong fuel line - sol'n -> general cleanup ng fuel line and the fuel tank na rin. After this chances are you'll need to replace the fuel filter din.
If it is not one of the above mentioned cases, this is what I do:
(Subject: Carb of a nissan A12 engine of a nissan sunny pickup, 91 model)
1) I make sure my timing is right....so tune it up first....
2) Run the engine
3) I slowly "open" the adjustment screw until the engine nears choking (die of too much fuel)....this is your theoretical "rich" setting
4) From there, I would "close" the adjustment screw...carefully counting the number of turns until the before the engine die due to lack of fuel...this is your theoretical "lean" setting
5) (Usually the engine dies) so before I restart the engine I would turn back the adjustment screw to "open" but only 3/4th the number of turns before it reach the "rich" setting. This is the theoretical "correct air/fuel" mixture or what they call yata stoich (correct me if I am wrong).
That's it. That method more or less work for me on that type of engine. If you ask me why "3/4th the number of turns", for me it is because...the "lean" setting is 16:1 and the "rich" 13:1 and the stoich is 14:1 ... so theoretically 14th is about 3/4th the way back going to the 13:1 from the 16:1.....did I confused you more???
My 2 cents, Peace.
I am very open for other suggestions.
- Aug 2003
- 125
August 25th, 2003 01:34 PM #3thanks wildthing, will check on this matter w/ the mechanic who will overhaul my carb.
August 25th, 2003 01:51 PM #4Originally posted by wildthing
2) Run the engine
- 3,790
August 26th, 2003 03:12 AM #6Originally posted by wildthing
2) Run the engine
My 2 cents, Peace.
I'll take your word for it. ;)
September 1st, 2003 09:24 AM #7
IMO, the best is to actually watch and learn from someone who knows... What i did the last time was i just brought the car to Kamias and had a shop open it up to clean it and adjust (cost me P350). The next time around, i'll have my carb-addict friend teach me hands-on already.
- Aug 2003
- 7
September 26th, 2003 04:02 PM #8wildthing..but there two adjustments sa carb...yung sa hangin at fuel...paano naman yung sa hangin...same prod. ba
- Jul 2003
- 573
September 26th, 2003 09:49 PM #9oldskul, you may be referring to the throttle adjusment screw? this is for setting the idle engine rpm and does not affect the fuel
air mixture.
What i normally do is to first set the idle engine rpm to the lowest
possible setting and then try to adjust the idle fuel air mixture for
best engine performance at both ends of adjusting screw travel and settle for midway setting. This is the idle speed fuel air mixture. When the throttle is opened, the fuel air mixture is conrolled by the jets and the venturri. there is no adjustment for this.
- Aug 2003
- 7
September 27th, 2003 09:03 AM #10thanks tip_tipid but ur way of adjusting is different from wilthings way...or maybe it depends on the machine....
ano po ba talaga best na tint/film ceramic (with >90% Heat Rejection [TSER], Better UV Protection...
