Results 1 to 5 of 5
- Jun 2009
- 11
June 29th, 2009 08:57 AM #1Hi guys,
Would anyone be able to tell me if my car's problem is a dirty air filter, or a sliding clutch... or both?
Here's what I've observed on my car...
When I drive it coming from being parked overnight, and the temperature is not yet at the average, it moves smoothly, but once it reaches the average temperature, I usually experience something like a rapid succession of pressing and releasing of the brakes. Parang may jolting motion yung kotse. Parang hirap din siya humatak.
I also sometimes find it hard to switch back to 1st gear. Di agad pumapasok.
Pasensya na, at wala akong masyadong alam sa kotse.
TIA.
June 29th, 2009 03:46 PM #2
gaano na ba katagal ang clutch mo at ang air filter?
kailan mahirap ipasok sa 1st gear? pagnakahinto ba ito?
at since masmura ang air filter go ka muna sa replacement ng air filter then observed mo muna, baka naman fuel filter kailan ka ba nagpalit nito baka barado na?
- Jun 2009
- 11
June 29th, 2009 04:10 PM #3Yes, pag nakahinto. Mahirap ipasok sa 1st gear after a full stop, sir, pero di naman palagi. Pasumpong-sumpong. Di ko lang sigurado kung gaano na katagal yung air filter at clutch. Di ko nakuha ang info sa previous owner. Balak ko naman dahil mamaya sa shop, pero gusto ko lang muna makakuha ng input dito. Baka kasi kung anu-anong sabihin sa akin ng mekaniko na di naman totoo. Maraming salamat!
I hope others could also give their inputs.
TIA.
June 29th, 2009 04:18 PM #4
check the the master cylinder and slave clutch kung may leak, if one of these ay mamasa masa may pressure leak na and need to replace the whole assembly (if needed) or repair kit lang.
re sa something wrong sa engine kapag nareach na ang normal temp i suggest - tune up, change fuel filter or baka due na ang car mo for pm
- Jun 2009
- 11
June 29th, 2009 10:43 PM #5Maraming salamat sa mga input. It turned out na ok pa ang clutch ko. One of the guys at the shop did the handbreak, 3rd gear, rev engine, release clutch test... namatayan naman ako ng engine. Sabi ko pakicheck at palitan na lang yung air filter at fuel filter, panigurado lang (parang lang may peace of mind ako sana na may ginawa naman kahit papaano doon sa kotse), pero buti na lang at di mapagsamantala yung mekaniko.
He had the servo checked, then had it cleaned and adjusted. Nag-test run kami, at wala na yung problem. Smooth na yung takbo, at di na mahirap timplahin ang gas at clutch, unlike before. I just wanted to share that in case somebody else encounters the same problem and thinks that it's their air filter or clutch that has a prob.
Yung shifting down to the 1st gear na problem ko, di pa umulit during the test drive, and on my way home. I don't know much about cars, pero parang di naman siguro na-fix yun dahil sa paglinis at adjust lang nung servo.
Thanks again for the input!
this is my biggest complain with EVs... the whole vehicle will be disposed later. no one wants...
All New Toyota Corolla Cross
