Results 1 to 11 of 11
    Good day
    Pauwi na po ako from Lipa on when i hear na maingay sa front wheels ko pag nag brake ako, akala ko po brake pads ko upod na pero nung i check ko kahapon ok pa naman yung brakes pero yung CV joint ko sira na yung rubber cover, tsaka may halong sand/stones yung grease niya sa CV joint
    ano kaya lagyan ko ng degreaser tapos apply uli ng grease sa CV joints tsaka saan ba nakakabnili nung rubber cover, tatagal pa kaya yung CV joint ko, mukhang ok pa naman, magkano na po kaya ngayon yun, sentra po tsikot ko
    you have to have it repacked.
    Aug 2005
    yep.. have it repacked immedietely para di ma-damage ang bearings. yung rubber boot mabibili sa auto supply.
    Sir magkano po pa repack, tsaka yung rubber cover
    thanks
    Replacement boot is Php130/ea. Packing grease is around Php75/ea. (medyo mahal na ito). At most you will need 4 boots and 4 packs of grease. Pwede din ata bilhin yung grease sa malaking lalagyan.
    I forgot the labor. Lumalabas mga Php300/side or less yata. May sinabay din kasi akong oil change and other stuff (pakyaw).
    Pinagawa ko lang sa Auto Supply ni GlennSter sa Kamias.
    Aug 2005
    Di ko sure pero sa Cruven (#44 1st Ave., Brgy. Bagong Lipunan, Crame Cubao Telephone #: 7277693/7226486) nakita kong gumagawa sila nito. tanong mo na lang kung magkano yung labor and rubber boot para magka idea ka.
    tapos try to find the most convenient shop in your area..
    Nov 2003
    have the bearings checked before replacing it. kung sira na sila kahit anong repack mo maingay parin yan.
    Yep, baklas na din naman lahat. Just remind the mechanic to check.
    Apr 2003
    1) Yung tunog ba ng sirang CV joint bearing, parehas ng tunog ng sirang wheel bearing?
    2) Posible bang masira yung CV joint bearing kahit na buo pa yung drive shaft boot?
    May 2007
    Speedyfix is right.
    Yes the cv joint races and balls due to dirt wear and lack of lubrication have slack and under acceleration around curves they pop pop pop. Or click that means there is no boot that is going to fix that slack. There are rebuilt half-shafts available but you must make sure you know if your car has Viscus differential with limited slip. The inner CV joint splines are different. Transmission number plate or door jamb sticker RE4F04A is open differential and RE4FO4V is limited slip viscus differential it has different axles so be careful. I would replace the entire half-shaft (s) or rebuit it and torque the axle nut to 172 to 240 foot pounds torque depending on the model of your car. Axle nut is either 2 1/4 inch or 36 mm. I am sorry I assumed your car has a four speed automatic transmission since you never mention anything about the vehicle but broken halfshalf boot.
    Nov 2007
    naku sir pagawa nyo na baka nadale na ang wheel bearing mo?
CV joint questions
