Results 1 to 6 of 6
December 27th, 2005 06:25 PM #1
My ride's left inner CV joint is leaking some grease from the clamped edge of the rubber boot. The boot itself is OK, no cracks or tears. Seems to be the stock clamp is not working as it should.
Would it be OK if I replace the stock clamp with a worm gear clamp?
December 27th, 2005 11:09 PM #2
The stock clamp can be further tightened.
If not, there are replacement clamps available.
Not sure about worm clamps. Almost all CV clamps I've seen are smooth.
- Feb 2004
- 200
December 29th, 2005 08:54 AM #4
there is a knocking sound kinda like tok-tok -tok-tok when turning (full) the wheel.
steeljack,
try to tighten the stock clamp by straightening, then pulling it then bending it to its locked position.
December 29th, 2005 10:03 AM #5
^with what afrasay? pede na pliers? wala kasi locking mechanism yung stock ko eh, mukhang simple steel band lang...
