Results 11 to 13 of 13
July 20th, 2007 02:12 AM #11
Most probably he was refering to the draglink or rackend. May rubber boot din yunand will empty your PS fluid when it gets loose or is remove from its mount. You should have seen it coming by way of knocking noise over potholes especially bumps during turns. Good thing you didn't hit a pothole doing soemthing over 20kph.
July 20th, 2007 11:01 AM #12
mga sir, i just came from servitek malapit sa'amin...rack end daw po un ntangal sa left...nun tinawagan ko un mekaniko nmin, ibang sasakyan pala un cnabi nya na cv joint un cra (un sa van pla ni erpats )....sabog kausap eh..anyways, i had it fixed na....tapos un right rack end, dapat daw palitan na din kc baka masira na kaya tumutunog na din...pasenxa na po mga sir, nde ko lam mga parts ng oto e. lesson learned: maintenance check-up po para iwas disgrasya. swerte pa rin, the left rack end went off while i was parked outside the house (masamang damo, matagal machugi ).Thank you, mga sirs.
July 20th, 2007 06:41 PM #13
Ayos good to go na ulit tsikot mo! Kakapaayos mo ng sasakyan you'll get familiar with these parts. Drive safe.
What vehicle and what's your budget?
