Results 1 to 9 of 9
- Jan 2004
- 40
March 8th, 2004 02:14 PM #1guys is there an easier way in taking out the crankshaft pulley ? or is there a special tool na gamit ?
wala kasi ko makita na lagayan pangkontra para maalis sya ng socket.
- Feb 2004
- 24
March 8th, 2004 02:23 PM #2kailangan mo ng air tool para matanggal mo yong bolt make sure tangal rin yon 4 bolt niya.
- Jan 2004
- 40
March 8th, 2004 05:03 PM #3sir kilwind,
aling 4 bolt ? isa lang nakikita ko sa center eh, sa 94 esi.
March 8th, 2004 10:50 PM #4
since the crankshaft will turn as you try to loosen the nut, you need to use the inertia (at rest) of the crankshaft and pistons. how? e di gamit ka ng "impact force" - use a hammer on the wrench. lagay mo yun wrench sa nut then hammer it in the direction it needs to turn (note that the nut may be a left-hand threaded nut, as oppose to conventional right-hand thread).
or you can try removing the starter and putting a wedge on the flywheel teeth to prevent the crankshaft from turning.
the 4 bolts kilawind is talking about is that sometimes there are 4 (or sometimes 3) small bolts on the pulley in addition to the nut on the shaft. i'm not familiar with your engine (or even my car's engine hehehe!) so i can't really tell if there are those 4 bolts.
you may also need a small puller to remove the pulley from the shaft.Last edited by yebo; March 8th, 2004 at 10:52 PM.
- Feb 2004
- 24
March 9th, 2004 02:12 PM #5tama si sir yebo puwede kang gumamit nang martilyo para mag loose yong nut, ang down side naman neto is baka ma damage mo yong tread ng crank shaft sa sobrang force pero subukan mo parin ingat lang sa pag pukpok baka daliri ang tamaan.
Tsikot Member Rank 5
- Nov 2003
- 3,849
March 10th, 2004 08:37 AM #6laking trabaho yan dude... i suggest leaving it to the pros.
why do you need to remove it ba?
- Jan 2004
- 40
March 12th, 2004 02:12 PM #7nagpalit me ng timingbelt at waterpump, boss migs, ok na naalis ko na.
thnaks guys for the suggestions.
- Nov 2003
- 3,849
March 14th, 2004 10:26 AM #9
sabi nga ng matatanda, walang pakipot na dalaga sa matigas na utin, este matiyagang binata pala ! luluwag din yan! laway lang ang katapat!
ooops! baka mademanda ako ng gabriela...hehehe!
Burberry Men Leather Jacket oskarjacket
Verifpro - paypal, ebay, banks, crypto, docs and...
