Page 2 of 2 FirstFirst 12
Results 21 to 36 of 36
    Sep 2005
    #21
    Cool it guys! When I doubt, just read the Owner's Manual of your vehicle, ok?
    Aug 2006
    #22
    Quote Originally Posted by mbeige View Post
    Blink, in your first reply you said why to wait a few minutes? Then your last reply prior to this message says you wait for 3 minutes. I don't get you.
    You didn't get what I intent to have said, in my early posts, I said you didn't have to wait 5-10 minutes, while on my previous post, I said it will take you 3 minutes you get to measure the reading after you shut off the car. Did you think I was telling you to pull over, step off the car, open the hood then go back to your car to shut it off before you pull out the dipstick?
    Yes, how do you measure if one's engine oil is overfilled? Diba when the oil exceeds the FULL mark? But question is when does that happen? Of course, when you fill up the engine knowing that when it was cold, the engine was already at FULL, and YET you still filled it up when warm. Correct?
    wahhhh... you'll know when it's overfilled when the dipstick says it's overfilled when the car is warmed up! Damn! You're not supposed to measure the oil level when the car is COLD so why say it's FULL when it's COLD??? Damn . . . :waah: How many times do people gotta ask questions that have already been answered?!
    Be it three, five, or ten minutes, the oil will still be warm. As long as it's between the full and low mark, then that's OK. But when it's cold, and it's between the full and low mark, then it's time to top it off. Correct?
    the temp of the oil when car's running isn't the same as the temp of the oil after you turn it off for 3 minutes! Again, you should not refer on the level of reading when the car is COLD!
    Dang, I'm done with this thread... I don't need to say things over and over, I've said it all, measure your oil when the car's cold if that's how you want to do it... mbeige, you don't make sense at all...
    Jan 2004
    #23
    Quote Originally Posted by russpogi View Post
    Tama!
    And this is what mine says:
    With the engine at normal operating temperature and engine is off...
    1. Best to be on level ground... wait a few minutes for the oil to drain back... Pull dipstick out.
    the_wildthing: Sorry, forgot the exact words on my way up. Pero sigurado akong walang nakalagay na exact minutes pero may rason kung bakit.
    2. Wipe with a rag...
    3. Put dipstick back all the way in.
    4. Pull it out and check the level...
    the_wildthing: may drawing pa.
    Jul 2006
    #24
    popcorn!!!
    :popcorn::popcorn:
    :peace:
    May 2005
    #25
    Yup, I also measure several minutes after the engine has warmed up and shut down. It's in my manual, and that's what I was taught in several seminars I have been made to attend as part of our company fleet accreditation/education.
    Probably, some of the other cars' dip stick were calibrated on a cold engine?
    Sep 2004
    #26
    Another Page 10 thread in the making? Hehehe, c'mon guys, lets not get all worked up over a petty thing like this.
    Basta ako, in my manual (Honda), approx. 4 liters ang capacity ng engine, so, cold engine or not, I always ask my mechanic to put in 4 liters (together with a new filter)
    Jan 1970
    #27
    i just did a little experiment. i measured the oil with a cold engine, car was parked over night.. and earlier today, i measured it with about 3-5 minute drain time, so warm engine pa din.. and guess what.. halos di ko man lang makita difference in oil level sa dip stick!!!
    #28
    wow, i didnt thing this tread was goin to be so exciting. hehehhe... for me i think its best to wait 5mins to before u check your engine oil.by the way i think that NAscar race cars have dry sum oil systems, so i think it would be different, from normal private cars.and i have also noticed that some cars have on the dipstick an add mark and a full mark. and like they say if ur oil level is between the 2 then your in the clear.anyways thanks for the insights. and ya i agree wit slip-slick, theres hardly a difference. whether the engine is cold or hot. because we liv in the tropics, where the weather is fairly the same temperature. in colder countries there might a significant difference.
    Mar 2005
    #29
    Quote Originally Posted by blink21me View Post
    Another case of failing to communicate clearly...
    "Wait 3 mins". That's a very important step. You just missed that completely.
    Jul 2006
    #30
    Quote Originally Posted by cocoy View Post
    this might be the reason behind the confusions
    pero ako katulad ni sir galactus, kung anong quantity ang sinabi sa manual yon ang sinusunod ko
    #31
    wag na kayong magtalo, alam ko na cause ng problem ng ride ko. Thanks for your enlightening answers.
    Aug 2005
    #32
    AFAIK, okey lng kaunti lumagpas sa high level..
    pero subra nakakabunol yan..
    #33
    i didnt miss the 3 min thing, i was stating that personally i wait 5mins,,,, ya its true lack of communication,
    #34
    parang tayong kongreso sa diskusyon dito ah oil level checking lang,nagkakatalo pa... hehehe. my simple advise, RTFM (Read The F***** Manual) na lang hehehe... whatever your auto manufacturer says, then follow it. Kung walang manual, then it's better to fail on the safe side... like ask youself, what's the worst that can happen if the oil level is a bit lower than Full or a bit higher than FULL? whichever will cause less damage, dun ka na lang.
    ako, i've always checked my oil level while my engine is cold coz that's what the manual says. But when I change oil, I start my engine and allow the oil to circulate a bit, then stop the engine, allow it to cool down, then recheck the oil level. that way, the old oil that's remaining inside the oil drains back with the new oil para mas tama yung oil level. hth... and peace lang tayo mga meyn
    #35
    i agree with you.... make love not war,.... hehehhe
    Sep 2005
    #36
    tagalugin na lang, para magkaintindihan...peace men!
confusing oil level indication
