Results 1 to 5 of 5
- Dec 2007
- 2
December 2nd, 2007 12:00 AM #1palaging nakailaw yong check engine ko ... tapos palyado pa ang kotse, sabi sa mega motion baka daw computer box na ang sira, narerepair pa kaya ito and ano-ano pa symptoms ng nagloloko na computer box?
December 2nd, 2007 10:09 AM #2
nah that's what old school mechanics say when they can't fix a car problem. i bet they didn't have an OBD scanner. bring it to a shop that like speedlab or speedyfix. baka loose or busted sensors lang yan.
Tsikot Member Rank 5
- Nov 2003
- 3,849
December 2nd, 2007 09:23 PM #3if it's a 96 civic it only uses a 3prong connector so easy to extract the code.
normally if it says the iacv is busted you will need to replace both the iacv and have the box fixed since the iacv tends to burn some diodes in the box.
we've repaired quite a few na with that problem.
- Jul 2017
- 1
July 5th, 2017 10:32 PM #5Is this thread still active? May tanong lang din sana ako regarding sa computer box ng sasakyan ko. Honda ESI 94 sya. Dalawang beses nang nasunog computer box niya. masakit sa bulsa kasi kapapalit pa lang wala pang isang lingo naisalpak iyong replacement sunog ulet. check ko ang old box same lang ang area kung saan siya nasunog. Baka matulungan nyo naman ako mga tol. Hindi pa ako gaano marunong sa sasakyan. Salamat kung may tutugon.
the triumph of man over... man!, using the crudest of implements (by modern standards).
Traffic!
