Results 11 to 20 of 24
October 7th, 2006 02:24 PM #11
Yung sakin laging 3.75 lts ang nilalagay pero pag tingin sa dip stick ay laging lampas dun sa level pero wala namang nangyayari.
October 7th, 2006 02:28 PM #12
Lampas siya during cold dahil you check the engine when warm. When it's warm and you check the engine, the oil is still in the engine upper components. But this is good dahil this is what you want, maximize the amount during operation.
October 7th, 2006 07:16 PM #13
Could damage gaskets. Damaged head gasket could get oil into coolant and vice versa.
If oil level reaches crankshaft it will be whipped into a foam which won't lubricate well. Exacerbated by driving fast through corners, centrifugal forces will shift the oil.
But apparently there's a bit of safety margin for oil overfill...
October 7th, 2006 09:37 PM #14
Kung hindi naman grossly overfilled, don't lose sleep over it. Hindi ka naman pagsasakluban ng langit at lupa.
How much did you overfill ba?
October 7th, 2006 10:50 PM #16
October 8th, 2006 05:40 PM #17
October 9th, 2006 08:14 AM #19
October 9th, 2006 11:20 AM #20
Or none of the above? We've had Ferraris and Lambos burn in SLEX and NLEX in the Philippines...
Hybrids and EV
