Im due for change oil but I still have problems with my spark plug o-rings near the rocker arm. Is it ok to have change oil then replace o-rings after few days?
How about change ATF, gaano katagal nila gagawin or me kalangan ba silang ibaba? THanks.
do it together if possible so that the new oil doesn't get wasted.
about the atf replacement, you'll need about 3 liters lang on a honda kasi most of it is in the torque converter and there is no way to drain it unless you bring down the tranny.
you could also opt to flush the system but you'll probably need about 10-12 liters of atf for that.
Assume this is for the ESI rin? So far had all my ESI ATF changes (40t, 80t, and 120tkm) done at Honda. All was done w/in the day together with the other checks for those respective kms.Originally Posted by ineedmorehp
