Results 41 to 49 of 49
June 27th, 2005 05:12 PM #41
what about Pertua? has anybody here ever used this oil? feedback naman...
Tsikot Member Rank 5
- Nov 2003
- 3,849
June 27th, 2005 10:44 PM #42repackaged here in the philippines... no idea tho about how good it is.
SiRaNeko
- Jan 2003
- 973
- Jun 2005
- 113
June 28th, 2005 08:01 AM #44Originally Posted by buknoy2002
On the other hand, it might even be beneficial to use thicker oil on older engines to compensate for the increased parts clearances, and minimize engine noise and enhance compression at the same time.
June 29th, 2005 08:17 AM #45Originally Posted by izzy
June 29th, 2005 08:20 AM #46Originally Posted by box_type
- Nov 2003
- 3,849
- Sep 2004
- 59
June 29th, 2005 02:02 PM #49Originally Posted by buknoy2002
yes, high mileage cars have bigger clearances on the ring-cylinder wall, and valve stem-valve guide areas which could cause leaks to the combustion chambers that resulting carbon build-up in that area.
use the thicker grade if you want synthetics or better yet, use the dino (mineral) oil and just replace frequently.
One feature they should incorporate in EVs is speed limiting based on the keyfob you hand over to...
