Results 11 to 19 of 19
August 4th, 2004 03:00 PM #11
may medyo OT question ako
saan ba gas station pwede pa change ng different brand of oil? kasi bumili ako ng citgo oil sa pricesmart and di pwede sa shell malapit samin kasi they only allow that if the oils brand is shell
August 4th, 2004 09:09 PM #14Originally posted by Chip
August 4th, 2004 09:27 PM #15Originally posted by CLAVEL3699
Someone told me na if you use synthetic dati then you change it to mineral pwede magkaroon nang leak ang gasket mo.
Tama ba ito?
I have a leak na sa gasket ko 'coz i change my oil to mineral base.
Ano ba solusyon dito balik ako synthetic or kailangan na palit gasket?
Thanks.
- Aug 2004
- 20
August 5th, 2004 12:35 AM #16clavel... synthetic n mineral based engine oil have the same chemical components.. the diff is synthetic lasts longer n has more additives rather than mineral base.
walang kinalaman ang gasket leaks mo sa engine oil. the best thing to do is change the leaking gaskets.
san ba leaks mo valve cover? cyl head? intake or exhaust valve gasket?
one more what grade of oil u using? baka sobrang nipis ang gamit mo
August 5th, 2004 01:03 AM #17
Sa oil pan gasket sya may leak.
Im using ngayon Caltex Havoline lang.
20w-50 ata yun.
Ok pachange ko na sya.
Ano ba maganda gamitin?
- Aug 2004
- 20
August 5th, 2004 02:50 AM #18ok kung sa oil pan gasket... better check what kind of gasket are u gonna use if its cork or not.
if cork madali kasi madurog if u over torque it. so the simplest solution if ur using cork is basain mo muna then let it dry under d sun. when its dry na matigas na yan. then install it na.
August 5th, 2004 10:18 AM #19Originally posted by GlennSter
what i do dati nung hindi pa kami nag cha change oil sa shop is put castrol oil sa shell na lalagyan.
as an aside, in the olden days, anyone who does not move 'ala luksa during Holy Week, especially...
Traffic!
