Results 11 to 16 of 16
- Aug 2006
- 70
November 21st, 2007 08:29 PM #11...or maybe your ignition switch. I had that problem before and tried to isolate it starting from the battery, starter then switch. After checking the battery and starter and found them to be okay, I surmise it should be the switch. So wired the starter lines from the switch and test it. My car started. Just my 2 cents.
November 21st, 2007 09:04 PM #12
I had that problem once, which was traced to a loose battery terminal connection. Replaced the Brass terminals, cost: 2 brass terminal 30pesos.
November 21st, 2007 09:36 PM #13
Have you tried checking checking your fuel filter? Next time it happens
try this...
1. Remove your fuel filter fom it's clip that is located in your firewall
with your left hand. Hammer it with the handle of a screw driver for
20 seconds to clear it.
2. Start your engine. If it works.
3. Buy a new filter and replace.
November 22nd, 2007 12:31 AM #14
i happened to me before...same sympstoms. the culprit is starter solenoid.
- Aug 2005
- 375
November 22nd, 2007 02:02 AM #15first check this thread: http://tsikot.yehey.com/forums/showthread.php?t=29335
2nd, since naka-15 attempt na kayo...ibig sabihin naubos na rin ang power ng batter nyo
try nyo munang ipa-series, kung umandar then may problema nga battery nga...replace it na.
last week na-experienced ko ito, nagpaseries na ako..nde pa rin umandar ang makina, walang "clik, clik" sound, walang "redondo"...pati mga fuse tinignan ko, wala din problema..ginawa ko tumawag na ako ng mekaniko na kilala ko...ayun in 10 minutes nakita ang problema, nakatanggal pala ang connection from the battery papunta sa solenoid...ang tanong..paano natanggal? since mahigpit ang pagkakalagay non!
Tsikot Member Rank 5
- Nov 2003
- 3,849
November 25th, 2007 06:19 PM #16you may want to have a mechanic go to you or tow your car to a shop para macheck agad.
