Page 2 of 2 FirstFirst 12
Results 21 to 33 of 33
    Aug 2007
    #21
    tama ka jan bro, galing talaga ng tsikot, newbie din ako walang alam sa kotse but I make it a point to read tsikot thread everyday, kaya medyo may alam na din. when i want to know something about cars, open ko lang tsikot. Big help yung mga gurus dito sa tsikot esp " theveed ". mine is lumang lancer glxi 1996 a/t wala pa namang problema, but i'm reading as much as i can dito sa tsikot para ready na ako kung may kailangan i-pagawa. goodluck mga bro.
    Nov 2006
    #22
    yup, ako din thankful kasi nalaman ko itong tsikot. dami ko talaga natutuhan. saka malaking tulong sya lalo na sa case ko.
    #23
    Quote Originally Posted by SpiritBeing View Post
    isang tip dyan hangga't maaari e bantayan yung gumagawa, kasi minsan hindi inaayos yung trabaho nila kapag hindi nababantayan.
    question po, kung magpapadetailing po ba advisable din na bantayan un gumagawa para sure na ayos ang trabaho?
    salamat!
    #24
    Ask ko lang mga sir, san po ba ung speedyfix? kaya po ba nila ang overheat? Kasi po ung car ko po nag-overheat sya kapag traffic at nakaon ang aircon pero habang tumatakbo at naka-on ang aircon ok naman po sya. Ano po kaya problem nun...sensya na po a...ilang beses na rin ako naloko sa banawe...purkit girl ako inaabuso ako...hehehehe...nissan 1995 po ung car ko...tnx!
    May 2007
    #25
    Quote Originally Posted by cherryfin View Post
    it's along Shaw Blvd., Mandaluyong City, katabi ng Puregold and Goldilock's.
    Jun 2006
    #26
    Speedyfix is in Shaw Blvd. Across Red Ribbon and almost beside Pure Gold. They have a big signage. Tel no 717-4202 look for Migs.
    Kung di ka nagoverheat pagoff ang aircon, most likely aircon fan ang prob.
    The reason it heats up during traffic is the AC fan can not push enough air to cool your engine. When running, you have enough airflow to keep your car cool.
    Simple test you can so is open the hood. Start the car and let it idle till it reaches normal operating temp. 1 fan should start up. Turn on AC, the other fan should also run. That, 2nd fan is your AC fan. If it does not run or is slower than your other fan, you found the culprit.
    #27
    meron po ba ditong taga bulacan o merong may alam na shop sa bulacan na magaling mag overhaul ng civic engine?
    Salamat...
    #28
    Quote Originally Posted by speedyfix View Post
    i don't think we'll be that cheap pero give us enough time to check the car and we should be able to pinpoint the problem for you.
    ayan ...sumagot na si speedyfix..
    #29
    Quote Originally Posted by macychic View Post
    salamat!
    mas maganda kung babantayan mo para alam mo kung ano ang ginagawa, tapos tanong tanong ka para matuto. pero kung kilala mo naman at may tiwala ka ok lang na wag ng bantayan.
    #30
    bro, wag kang magpa repair kung kahit saan saan, pa repair ka dun sa medyo kilalang mga shops, wag din dyan sa rapide, dami ko ng narinig na negative feedback tungkol dyan and na witness ko mismo yung inconsistency nila sa pag gagawa ng service. basta as long as mapagkatiwalaan yung shop. recommended sa CASA tlaga which i usually have my car fixed since they really know what they are doing.
    Sep 2006
    #31
    saken din ganyan..that is why you need to set aside at least 30k for repairs after buying a 2nd hand car.... parepareho po tayo experience but we learn from our mistakes.... it will be worth it pag naayos naman... im sure may warranty naman ung pinagpagawaan mo na shop kaya ibalik mo sa kanila
    Jan 2008
    #32
    TS: yang Caltex ba na yan sa may greenhills e yung nasa kanto ng Club Filipino drive? at yung mekaniko na sinasabi mo e naka bike? eto ginawa nya sa akin:
    nasiraan ako ng clutch, di pumapasok yung kambyo. sbi ko sa kanya palitan nya lang yung secondary (yung nasa baba). ayaw ni mokong, gusto nya buksan din yung clutch master (primary). ayun pinalitan nya ng repair kit yung dalawa. alam mo kung ano nangyari... kinabukasan tumatagas na yung fluid ng primary clutch sa loob ng kotse ! bumili tuloy ako ng bagong clutch master assy at nagbayad pa sa ibang mekaniko! kung di lang talaga emergency. nag txt nga ko sa kanya e, di nag-reply
    #33
    salamat!
    if you can keep an eye much better.
    but if the detailing is done sa bigberts, not required. laro ka na lang dun sa lounge nila.
car problems. Need help! please!
