Results 1 to 15 of 15
    Jul 2003
    Where can I find good car electricians, I mean the best of the best, may electrical problem kce car ko, yung pillar gauge pero parang wala na ata electrician na makagawa, galing sya sa options unlimited pero nag resign na si fred at jimmy, sa banawe I've let this certain maxim check it pero hindi ako convinced
    san ba makaka hagilap ng expert electrician, walang hula hula, accurate answers to my car problem?
  2. #2
    ano eksakto sira bro?
    pre sa Wizards sa Tomas morato balita ko magaling daw dun
    Jul 2003
    Kce I have volt meter and oil temperature meter, may siren din tsaka strobe light, dati it's working properly pero since mga 3 months ago pa, nagloko sya na if I open the headlights, the voltmeter drops from about 13.7 to 12.5 tapos the temparature increases from 85 to 160, pag nag siren ako tumataas din temperature well pina disconnect ko muna lahat pero ganu pa din pag open ng headlights, I suspect may ground sa may bumper where the siren is located. pero mga electrical shop mga tamad mag bukas ng bumper so hindi ko talga makita, lagi nila sinasabi hindi dun yun without looking at it, well how would they know e hindi naman nila ma solve, it would make sense to just try it diba..
    What I'm not sure if the voltmeter is not working properly which is unlikely... nag test na rin ako direct sa battery and volmter gauge ko, hindi cla pareho, my multitester reads about 13.5 fully loaded yung car bukas lahat pero sa voltmeter ko is mga nasa 12 lang.... pano ba to?? nahihilo na ako kakahanap ng electrician na magaling
    Jul 2003
    thanks subukan ko nga
    yup..wizzard magaling..pricey but magaling..
    Got Mazda?-http://www.MAZDAtech.org [SIZE="1"]est. 2000[/SIZE]
    got mazda 2? -> mazda2ners
    Medyo mahal dun. Php 120.00 agad ang basic check.
    Pero ok naman.
    Jul 2003
    Thanks sa replies niyo, tried wizard na, aba Wizards nga cla
    They were able to fix my problem, took them about 2 hours to fix my electrical problem, pero naayos nila, galing
    medyo mahal lang nga, cost me 680 pesos, but hey, no one's gonna fix it for me anyway
    ano daw ang naging problema?
    Signature
    yah.. ok dun sa wizzards... dun din ako nagpagawa dati nun nagloloko ang lights ko sa lancer
    Jul 2003
    hindi daw maayos pagkakabit, yung mga wires daw hindi tightly connected
    good to hear na naayus nila...
    guys anyone who knows the contact number of wizards?
    Jan 2003
    try nyo po sa recommended shops forum. alam ko nandun contact no.
    pag wala nasa yellow pages po
    Jun 2005
    Quote Originally Posted by rukawa
    ...What I'm not sure if the voltmeter is not working properly which is unlikely... nag test na rin ako direct sa battery and volmter gauge ko, hindi cla pareho, my multitester reads about 13.5 fully loaded yung car bukas lahat pero sa voltmeter ko is mga nasa 12 lang.... pano ba to?? nahihilo na ako kakahanap ng electrician na magaling
    If the V/meter and the temp gauge both share the same ground, it would be likely that it's not making good contact.
    Check both connections for those 2 gauges.
Car electricians
