Results 31 to 32 of 32
December 30th, 2005 01:38 PM #31
the camber setting will vary per vehicle model. though it is slighty leaning to negative.
the inner tires will slighty wear out faster, but you can counter this by flipping over your tires (so that the inner tires will be the outer tires) and switching them to the other side.
sa servitek autocamp / meralco ok gumawa ng alignment / camber adjustment.
Tsikot Member Rank 5
- Nov 2003
- 3,849
January 2nd, 2006 12:37 PM #32depends kung parehas ynug tread even if you switch it over. minsan if ganunin mo maugong yung tires.
