Page 1 of 2 12 LastLast
Results 1 to 20 of 32
    Mar 2004
    Can civics particularly Sir's be cambered? Got my Sir wheel aligned, but the mechanic says the camber adjustment is fixed????
    Is there anyway to get the front wheels cambered?
    Apr 2004
    had the same problem with my mazda pare.... mali nga yung pinagawa ko e, kinikil lang yung shock mount.. anyway na camber din naman....
    i hear there are such things like camber plates and bolt para sa mga non adjustable e....
    Jan 2003
    the civic's camber is not adjustable. but it can be pressed to be straightend back to its original position.
    Yeah, sadly pine-press lang >:E Yun ang nalaman ko a few months back lang >.> Anyways, sa Servitek ba nagppress?
    Mar 2004
    sa likod lang may camber ang civic sa harap fix
    Sa harapan ung naging problema nung akin >_< Ang pangit ng kain ng gulong >.> mejo bago-bago sya pero ung sa loob kita na ung bakal >.> Anyways ang ginawa is pinress nga nila :3 And un mukhang ok na sya, maayos naman ang gulong since then.
    yes it can be adjusted pero kailangan bumili ng aftermarket camber kits.
    related thread:
    http://tsikot.yehey.com/forums/showt...ghlight=camber
    Ang pagkaka alam ko ang EK civics cannot be cambered unless you get a camber kit.
    The ES civics can be cambered
    Apr 2004
    wala kasi ako kumpiyansa na sa press e.. my old school car did'nt had any way to adjust camber din dati.. i always resorted to having it pressed, sa zafra dati.. i always end up having to do it yearly...
    Mar 2004
    Thanks guys and gals sa reply....yun nga ang dillema. At least now i have to look for aftermarket cambers.
    Anybody who has an idea kung how much?
    Zee Carplus is confident that they can correct the 'camber.' Haven't tried though.
    Nov 2003
    whoever says it can be cambered without a camber kit or without cutting up, heating or modifying your suspension in one way or another is yanking your chain.
    Feb 2003
    for the front, you need aftermarket camber kits, for the rear it can be corrected using camber shims.
    never go for the heating and other methods that would compromise the integrity of your suspension parts.
    Apr 2005
    Quote Originally Posted by bigfeather8888
    it can be pala by heating, kaya lang me consequence.nasa me ari nayan kung gusto niya o hindi
    Apr 2004
    my EK needs a camber na rin. anybody know where i can buy those aftermarket camber kits and how much they cost?
    Eibachs are sold at around 10K a pair in tirerack.com. I'm not sure if other brands are available.
    It's too bad the EK's front camber is fixed to a negative alignment. It's an economy car and most owners of which want equal tire wear. I myself wouldn't have a problem were it fixed to zero.
    Nov 2003
    skunk 2 used to sell their kits around $200-250++
    Oct 2003
    i have a problem with my rear..negative yung tires..what do i need to do? im using neuspeed 2inich drop and stock shocks..my ride is civic lxi
    Mar 2005
    ako din problem front tires ng sentra ko. naging sakang nung nagpaayos ako ng shocks sa zee. fixed din front camber ng sentra. san po banda maganda magpa camber?
    Thanks
    Aug 2004
    I know Minerva can do it, I've had my Sentra's camber fixed there before... but since this involves drilling out and adjusting the holes where the strut tower meets the wheel hub, it needs to be adjusted again and again afterwards, every five to ten thousand km or so, as the bolts still slip sideways within the holes after long use.
    The back can't be cambered at all... not unless you're willing to have the beam bent... but there aren't any local shops that can do this reliably.
Can Civics be Cambered?
