Can civics particularly Sir's be cambered? Got my Sir wheel aligned, but the mechanic says the camber adjustment is fixed????
Is there anyway to get the front wheels cambered?
had the same problem with my mazda pare.... mali nga yung pinagawa ko e, kinikil lang yung shock mount.. anyway na camber din naman....
i hear there are such things like camber plates and bolt para sa mga non adjustable e....
the civic's camber is not adjustable. but it can be pressed to be straightend back to its original position.
Yeah, sadly pine-press lang >:E Yun ang nalaman ko a few months back lang >.> Anyways, sa Servitek ba nagppress?
Sa harapan ung naging problema nung akin >_< Ang pangit ng kain ng gulong >.> mejo bago-bago sya pero ung sa loob kita na ung bakal >.> Anyways ang ginawa is pinress nga nila :3 And un mukhang ok na sya, maayos naman ang gulong since then.
yes it can be adjusted pero kailangan bumili ng aftermarket camber kits.
related thread:
http://tsikot.yehey.com/forums/showt...ghlight=camber
Ang pagkaka alam ko ang EK civics cannot be cambered unless you get a camber kit.
The ES civics can be cambered
wala kasi ako kumpiyansa na sa press e.. my old school car did'nt had any way to adjust camber din dati.. i always resorted to having it pressed, sa zafra dati.. i always end up having to do it yearly...![]()
Thanks guys and gals sa reply....yun nga ang dillema. At least now i have to look for aftermarket cambers.![]()
Anybody who has an idea kung how much?
Zee Carplus is confident that they can correct the 'camber.' Haven't tried though.![]()
whoever says it can be cambered without a camber kit or without cutting up, heating or modifying your suspension in one way or another is yanking your chain.
for the front, you need aftermarket camber kits, for the rear it can be corrected using camber shims.
never go for the heating and other methods that would compromise the integrity of your suspension parts.
Originally Posted by bigfeather8888
it can be pala by heating, kaya lang me consequence.nasa me ari nayan kung gusto niya o hindi![]()
my EK needs a camber na rin. anybody know where i can buy those aftermarket camber kits and how much they cost?
Eibachs are sold at around 10K a pair in tirerack.com. I'm not sure if other brands are available.
It's too bad the EK's front camber is fixed to a negative alignment. It's an economy car and most owners of which want equal tire wear. I myself wouldn't have a problem were it fixed to zero.![]()
i have a problem with my rear..negative yung tires..what do i need to do? im using neuspeed 2inich drop and stock shocks..my ride is civic lxi
ako din problem front tires ng sentra ko. naging sakang nung nagpaayos ako ng shocks sa zee. fixed din front camber ng sentra. san po banda maganda magpa camber?
Thanks
I know Minerva can do it, I've had my Sentra's camber fixed there before... but since this involves drilling out and adjusting the holes where the strut tower meets the wheel hub, it needs to be adjusted again and again afterwards, every five to ten thousand km or so, as the bolts still slip sideways within the holes after long use.
The back can't be cambered at all... not unless you're willing to have the beam bent... but there aren't any local shops that can do this reliably.
