Results 1 to 13 of 13
    Jan 1970
    Can anyone post a step by step DYI procedure for a pizza lancer 4G92 SOHC valve tappet adjustment?
    Thanks a BIG (",)
    Nov 2003
    before you start you should know the measurements and have a feeler gauge so you can actually measure the clearance.
    if you don't have a mechanical background this is one procedure i do not suggest DIY for. yung iba pwede pero this is inside the engine itself na so if anything goes wrong mejo malaki na gastos mo.
    bring it to a gas station or talyer nalang and at least sure ka they know what they're doing
    Jan 1970
    yup i know i used to be an aircraft mechanic but i don't know the right gap values to be used actualy i've seen how it is being done and it look's simple enough that i would like to try it my self, well if nobody here knows this, i'll probably bring my car to your shop, hehehe, BTW thanks for answering my inquiries re KYB shocks for my lancer yesterday (",)
    Nov 2003
    no problem
    self-adjusting nga ba ang 4g92 sohc? medyo maingay din kse yun lancer namin eh.
    self-adjusting nga ba ang 4g92 sohc? medyo maingay din kse yun lancer namin eh. ok lang ba patagalin to or dapat na ipa-adjust? what would happen if we don't adjust it? thanks!
    Nov 2003
    adjusting the valve tappets will quiet down the engine, improve gas consumption and allow the engine to run more effectively.
    Quote Originally Posted by pdc2
    nope it's not self adjusting, ang alam ko lang na self-adjusting among the mitsu line-up is the 6A12 DOHC ng Galant VR V6.
    HTH
    May 2005
    so yung mga 1995 na galant v6 engines are self-adjusting? meaning you don't have to adjust the tappets anymore?
    sorry, i'm not familiar with mitsu engines e... :P
    thanks!
    Nov 2003
    when they say self adjusting this means walang adjustments. problem naman nyan is kapag umingay you have to pull most of the head out to replace the worn parts... unlike those with rocker arms that you can just tighten.
    Jan 2003
    how often should valve adjustments be done?
    every 10K?
    Jun 2004
    alam ko ginagawa lang yan pag maingay na yung engine, sa honda every 30k pwede na cguro, not sure sa mitsu.
    up ko lang... i recently had my car's valve tappets adjusted...
    after ko kasi magpalit ng timing belt humina ang hatak. so it was found na delayed ang timing. timing was adjusted and ok na gumanda ang arangkada. kaso nagkaroon naman ng tope, i'm not sure kung tope nga kasi alam ko tumotope ang makina if your rpm is too low. pero yung sakin naman eh during acceleration lumalabas. above 2k to 3krpm above and pag inaapakan ko ang gas... medyo matining ang tunog, parang may kumakalansing, pino ang tunog nya? is this normal? medyo matanda na rin naman yung oto, 97 civic lxi. appreciate it if you can help me diagnose this. thanks!
Valve Tappet Adjustment - 4G92 SOHC
