Results 1 to 10 of 10
January 26th, 2007 10:53 AM #1
mga bossings,
ang coolant reserve ko may maliit na butas yung sinasaksakan ng rubber tube. yung papuntang radiator.
puwede bang epoxy or kahit anong sealant dun?
ano mga possible na mangyari kung maiwan pa ng ganito ito?
January 26th, 2007 12:48 PM #2
get a new hose and new clamps... otherwise, you'll keep losing coolant and might overheat...
January 26th, 2007 03:25 PM #3
silicone sealant can be used. just make sure na dry ung surface upon application.
January 26th, 2007 04:58 PM #4
Yup, silicone sealant can be used, but it will be subjected occasionally to high pressure. Mura lang naman yung hose na yun, kasi maliit lang yung diameter at maigsi lang length. Yung clamps naman 5petot each lang. So buying a new one is a better alternative
I tried the high-temp silicone sealant on my PS hose. Di umubra, talagang malakas masyado pressure from the PS pump. Which is why most replacement PS hoses are steel-reinforced.
- Nov 2004
- 141
January 28th, 2007 11:10 AM #5yung plastic container ba mismo ang may maliit na butas?
pioneer epoxy gamitin mo kung medyo malaki ang butas. linisin mo lang ng mabuti at lihain ang application point. madalas may langis-langis yan.
January 28th, 2007 11:24 AM #6
January 28th, 2007 12:19 PM #7
January 28th, 2007 04:41 PM #8
palitan mo na lang, maraming mabiling hose na ganyan, it won't cost you 100 siguro
January 29th, 2007 10:45 AM #9
hindi nman sa rubber tube ang butas. kung duon, eh di pinalitan ko na for safety reasons.
dun sa parang elbow na kinakabitan ng rubber tube. ito yung kulay puti(m) na plastic na coolant
raserve.
ang ginawa ko nilagyan ko lang ng puting sealant, yung nasa parang toothpaste ang lalagyan. ayos naman. wala na butas. pag me suweldo na palit na ng reservoir
January 29th, 2007 11:15 AM #10
if it's on a 95 civic (EG) you should be fine, that reservoir is simply an overflow tank, it doesn't get pressurized or anythin' at all. you can even go without it...
