Results 1 to 17 of 17
    Apr 2006
    there is a stretch of road i drive daily sa amin na maraming lubak caused by water pipes. these are diggings crossing the road for water pipes pero hindi na tinabunan ng maynilad.
    according to a driver neighbor, dapat daw iba ang treatment ko when driving over them. pag yung bump daw kasi pataas (like yung ordinary speed bumps na pataas), i should slow down. pero pag itong mga ito, i should maintain speed as not to feel the full force of the "tagtag".
    usually, i slow down. pero dati di ko napansin na i was crossing one and parang totoo yung sinabi nya na it's better when you're going over them fast.
    any thoughts from you guys?
    At times nga, pag tagtagan ang usapan, mas hindi ko nga rin ramdam pag maintained ung running speed ko. More better to ask would be this though:
    Ano effect nito sa shocks ng sasakyan? which is worse for the car, ung maintained speed or slowing down?
    Aug 2005
    Slowing DOwn para sakin.. di nman as in "tag" basta slow lng like a diesel engine climbing uphill with lubak2x condition..
    Apr 2006
    palagay ko depende sa lalim at diameter ng lubak eh. pero kung yung tsikot mo pang-off road, malamang matibay tibay yan.
    yup depende sa lapad pag smaller than the contact patch, drive over it, the momentary lift dahil sa speed mo will make the ditch unnoticeable, pero kung wider than contact patch, sakit sa gulong yan.
    Jun 2006
    Quote Originally Posted by batang_raon14
    whoa this is a very good observation ha. oonga noh...hmm...naalala ko tuloy yung sinabi ni Einstein, tagalogin ko na lang po...sabi nya, mas mabilis ka daw mabasa ng ulan pag mabagal ka tumakbo, kumpara sa tumatakbo ka ng mabilis pauwi ng bahay. do u believe on this? well parang noh... walalang shinare ko lang.
    ngayon sa tanong mo na which is worse for the car, ung maintained speed or slowing down? i would better slow down lalo na kung lubak talga or humps.
    q:-)
    well, if you slow down to a point na gapang talaga walang effect at all sa suspension mo... that's the best option.
    Apr 2006
    *buoey_tisoy
    baligtad naman yung narinig ko. pag mas mabilis ka daw, mas mabilis kang mababasa as compared kung mabagal ka maglakad/tumakbo
    back to the topic:
    mukhang ok yung medyo mabilis sa case ko. wag lang harurot at malawak(?) yung hukay. ok lang malalim basta yung diameter ng lubak ay significantly smaller kesa sa diameter ng gulong ko
    Jan 2004
    depende yan. ako pag maliit ang gulong nang dinadrive ko(read: sedan), slow down talaga kasi eventually it will take toll on your underchassis parts. pero kapag yung malaking gulong (read: pick-up) ang dala ko, ok lang, kasi sturdy naman ang pang-ilalim. pero ingat pa din. tagtag e.
    Aug 2005
    unless kung tag tag na talaga shocks mo and go for it! 10kph ka or more! hehehe..
    slow down lang.. ang rack end mahal, bushing , suspensions etc. :lol:
    Quote Originally Posted by wewoy_romero
    depends.. if the gap is relatively narrow, I keep my speed up.
    Nov 2003
    ok lang naman to go fast over them if your car can take it. minsan lang kawawa yung suspension kung dinerecho mo.
    Aug 2006
    Marami rin nag sabi niyan best is to iwasan mo if kaya sinabi sa akin na king butas maganda mabilis kasi para hindi na maramdaman ng shock absorbers pag pataas slow down.
    For me, the best thing to do is maintain a constant speed as you run across the pothole.
    If you brake just before a pothole, the weight of the vehicle transfers to the front suspension thus exaggerating the impact forces both on you and on the vehicle. Ganyan kasi mag-drive isang driver namin dito. Nasubsob na nga kami sa pagpreno niya, naalog pa kami pagtama sa lubak. Kapag ako nagmamaneho (using the same vehicle) I just glide over the same potholes.
    Unless ga-higante talaga mga craters diyan, best option mo nun is to brake early para hindi stressed ang front suspension during the moment of impact.
    Sep 2010
    Mga experts, instead of starting a new thread, i decided to revive this one.
    With the onslaught of road re-pavementing plaguing our entire region, our cars are suffering. We have to travel through poked roads. Which is better, must we speed up or slow down? Is there a different "ideal" speed, say, when you drive a subcompact through these roads, as when you drive an AUV through them? I posted pics of what we go through on a daily basis. Part lang yan, kilometers ang span niyan. Di rin pwede pumili ng lane kasi most of the time puno both lane.
    Quote Originally Posted by torque&pepper View Post
    On roads like that, it is better to slow down. But there is no ideal speed.
    Jun 2007
    pag ranger, ratrat.
    pag mazda2. slow to a crawl.
    :rofl:
bumps on the road
