Results 41 to 50 of 54
October 27th, 2006 12:10 PM #41Although more often than not, dealer maintained cars have a higher resale value compared to those serviced by independent shops
Dealer service records can also be doctored if you know the right people.
Tsikot Member Rank 4
- Jun 2006
- 2,605
October 30th, 2006 07:19 PM #42Got the car back from Autohaus. They suggested some repairs that are not critical but expensive. Told them not to do it. Where can I have these fixed:
1. engine noise from alternator mechanical tensioner
2. engine noise from alternator deflection pulley
3. engine noise from a/c mechanical ensioner
4. suspension noise from rear guide support left and right
5. suspension noise from control arm bushing
Yung 1,2 and 3 pulley kaya ito o bearing?
4 and 5 pwede kaya kay Cruven?
October 31st, 2006 04:08 AM #43
You can have those done in Top Gear in Aurora Blvd mga 2 blocks away from Nestle House, edsa bound.
October 31st, 2006 06:35 AM #44
- Jun 2006
- 2,605
October 31st, 2006 10:33 AM #45We used to have our cars serviced there. Unfortunately, their service kinda took a nose dive.
For 1-3, the engine sounds rough. I don't know what it is or where it comes from. Can't pin point it. All I know is that it does not sound as smooth as it should. 4-5, I do hear suspension noise like a clunk or thud. I suspect that it is a bushing.
Saddly, I am not mechanically inclined and would probably do more harm than good to the car. Heck, I was once trying to fix a toilet and ended up damaging parts that had nothing to do with the problem. My wife still reminds me about it. So I rather let real mechanics do the work.
Zombie
- Aug 2006
- 728
October 31st, 2006 05:58 PM #46We can service BMWs at Autotechnika-Fort (and we also have aftermarket parts )
Contact Tommee Teng at 856-1881.
November 13th, 2006 12:11 AM #47
from EDSA cubao its just a few meters away. If you see the burger machine stand on your right that's the shop behind it. look above and you'll see the blue signage.
Autovec's numbers are: 725-6914, 726-2978. Look for Werner Reimer, 0920-9268100.
Autovec's address is 479-A E. Rodriguez Sr. Ave., Cubao, Q.C.
HTH
- Dec 2006
- 61
December 9th, 2006 01:09 PM #48singit lang po ako, i need to have an indepth inspection of our 95 bmw 316i, kelangan kasi maging reliable sya ulit lalo na sa mga out of town driving, delikado masiraan.. mga magkano budget kelangan ko ihanda for inspection 1 n inspection 2? meron po bang nakapag pagawa na dito sa autovecs? or autotechnika? or top gear? magkano po inabot? salamat!
- Jun 2006
- 2,605
December 9th, 2006 02:26 PM #49Di ko pa natry sa autovecs at autotechnika. May thread about autotechnika sa goon squad. Although it seems that they have solved the problem and tsikoters are happy with them.
Dati sa top gear kami nagpapaservice. Pero nung huli di na maganda ang nangyayari. As in charge nila kami for 8 liters of oil eh 4.5 liters ang laman ng van ko. They replaced rear brake pads, after 10,000 kms they want to change it again. Our other car, they replaced the drive belts, around 3 months later may tama na ulit.
You can also try Speedyfix.
- Sep 2006
- 41
Has anyone of you tried buying or installing front bumper that's made in taiwan (yung...
