Results 11 to 16 of 16
July 1st, 2004 11:18 AM #11
Rolandml::: One thing for sure, if you add one liter of oil per week. Loose compression state na.
Sign of wear ang usok sa dip stick entry & engine oil cap. There's the possibility that your engine will consume one liter of oil inbetween oil changes. Which is normal for a commonly used engine.
Tsikot Member Rank 3
- Oct 2003
- 734
July 6th, 2004 12:33 PM #12rolandml>>>>>>>>>ako naman same problem din ewan ko kung ipapaoverhaul ko or change engine. problema ko sa overhaul palpak 2 beses na ako nagpa ayos napalaki pa tuloy gastos ko palit dyan palit dun hala sige palit ayos just to restore daw in excellent running condition sige naman ako after 6 months pucha pumupugak na makina ko, hirap umakyat, kumakadyot ang dami pa oil leaks. siguro kung sigurado ka na magaling yan nag ooverhaul sa oto mo---siguro propesor ng mechanical engineering o automotive engineering go for it pero kung yun mga mga nakatapos lang ng vocational or less palpak talaga gawa ng mga yan. overhauling from what i have read is a very complicated procedure dapat lahat precise ultimo down to the last detail, the clearances should be right down to thousands of an inch measurement. sa change engine the only thing you need to do is to be sure na ok yun engine na makukuha mo check for signs of overheating, oil leaks, gasket problems, compression etc. dami sa internet check mo yun tips(search ka lang ) you may use measurement tools if allowed etc.. kaya ko naman nasabi change nalang kasi ganun kasi nangyari sa transmission ko nung una nasira then tanong ko sa mga mekaniko magkano abutin 10,000++ good thing may nakapagsabi sakin na kung papaayos ko daw trans ko malamang di maibalik ng maayos yun mga rotating gears sa loob so sira din dahil naexperience na ng frend ko yun. ginawa ko change trans nlang ako buti nalang yun trans na binigay sakin sariwa talaga as in binuksan lahat kita ko hangang sa pinakamaliit na washer at conditions ng mga gears. so yun 4 yrs nato trans ko no problems naman think about it.
July 9th, 2004 11:12 AM #13
It's but normal that when you pull the dip stick or open the oil cap of your engine while running idle may konting pressure at tatalsik ang oil. Compression test is the best way to determine if yung engine eh blowby na. Also check your air intake valves. If there's oil there then blowby ang engine. Here's a link that might help understand what blowby means:
http://www.bobistheoilguy.com/blowby.html
July 11th, 2004 06:19 PM #14Originally posted by boydapa
July 11th, 2004 06:22 PM #15Originally posted by boydapa
July 12th, 2004 12:23 PM #16
Additional info. Oftentimes blowby is caused by defective PCV (Positive Crankcase Ventilation) valve. Check the valve first before you decide to overhaul your engine. THis is the usual cause of blowby wherein blowby gases tend to find other outlets to escape the engine. For additional info on PCV visit this url:
http://www.autotune.com/cprotest/cpc8c.html
^ geo yatta of bulacan, ang nagcause ng traffic sa NLEX eh hinid minimum wage earners. Mga...
Traffic!
