Results 1 to 16 of 16
    Aug 2005
    gud morning guys. i usually do short trips (less than 5 km), city driving. tanong ko lang kung anong mas bagay na plug?
    does our hot and humid climate prefer hot or cold spark plugs?
    Nov 2003
    stick with the 5
    what's your car?ok lang pareho..but id say 5.
    Aug 2005
    2004 civic. nasa manual yung dalawang sparks na yan. another question, denso k16pr-u11 or k20pr-u11? nasa manual rin to. thank you guys.
    Jun 2004
    hmmm, pag ako bumibili ng plugs binibili ko yung nasa 6 or 7 na heat range... cold plugs hinahanap ko. pero basically i just follow the recommendations in the car manual for hot climates.
    http://www.ngksparkplugs.com/techinf...000&country=US
    Jun 2004
    eto yung gamit ko: Denso KJ20CR-L11 (equivalent to NGK ZFR6F-11)
    For hot climates eto recommended: ZFR7F-11 or KJ22CR-L11
    For cold climates: ZFR5F-11 or KJ16CR-L11
    (For Honda Accord pala itong gamit ko)
    Aug 2003
    what is the effect of "cold" or "hot" plugs? any effects on performance? my manual recommends BKR6E but then it also recommends the use of 0W30 oil... :P
    BAsed on the plugs choices mentioned, it's for a Civic it seems.
    Given the short distances, stick with the "hot" 5E's instead (cebu city is pretty much stop and go driving with short distances). But if you experience any detonation, switch to the 6E's.
    The cold and hot plug type refers to the optimal operating temperature range of the sparkplug. The higher the heat range, the plug will burn better under higher temps (high rpm, high speed, long engine operation, hot weather, etc.). CMIIW
    Speedyfix, what would the difference be between plugs with the "-11" suffix oer those without the "-11"? (i.e. BKRE6E-11 vs. BKR65E).
    May 2004
    i think "11" is the gap size between the electrode that is preset by the manufacturer. i think lng hehehehe
    Jun 2004
    11 is the spark plug gap (1.1mm)
    For more info check
    http://www.ngksparkplugs.com/techinf...tnumberkey.pdf
    Quote Originally Posted by orly_andico
    for the 323, you either have the option of using the bkr5e (hot) or bkr6e (cold).
    basically, the 5 is more suitable for city driving (lower temperature / engine speed). while the 6 is for higher temperature / engine speed.
    colder plugs (the 6) will give you a better fuel economy - though it has a higher tendecy to foul up (if you don't 'exercise' your engine often).
    Aug 2005
    mazdamazda why do colder plugs give better fuel economy?
    i do long drives(25-30 km) occasionally, are the bkr5's gonna be fine?
    san ba makabili ng torque wrench?
    Jun 2005
    pwede ko ba lagyan ng bkr5e-11 yung auto ko na ang stock plugs ay bk5e-11?
    what's with the 'resistor'?
    Feb 2005
    -11 is for car with catalytic converter..
    Nov 2003
    no need to torque plugs. hand tighten lang.
    Quote Originally Posted by astinagt
    Thanks!
bkr5e-11 or bkr6e-11?
