Results 21 to 25 of 25
February 8th, 2007 03:41 AM #21
another way to find out if sa tranny or hindi is to shift to neutral while cruising. pagnawala yun ugong nasa tranny ang fault if nandun pa rin sa wheels malamang ang problem. right now may issues sa autotechnika but still I would recommend that shop also speedyfix and sa mga nearest servitek near you.
February 8th, 2007 03:49 PM #22
thanks sir for the suggestions. this morning habang wala akong ginagawa, pinagpalit ko yung tires sa likod and front. nawala ang tunog, problema naman when reaching 60 kph nag wiwiggle na ang steering wheel. so binalik ko na lang muna sa dati. kahit medyo may ingay di naman nag wiwiggle... at least may palusot na ko ngayon para mag upgrade ng rims and tires...
February 8th, 2007 10:04 PM #23
can someone please explain how tires can make such noise like broken bearings do?
mejo curious kasi ako bakit may ganun cases. and what is the solution to this problem.
thanks po!
February 8th, 2007 10:40 PM #24
bro ,pag ka deform or oblong na ang tire kaya pag takbo mo hindi na pantay ,kaya makakarinig ka ng noise na parang sira or maingay sa tires,
na experience namin ito sa REVO ng pinsan ko
(stock tire may umbok sa ,gitna).,loaded ang sasakyan magdamag nakapark , after ma unload nag iba ang takbo nag palit lang kami ng tire nawala na iyon annoying noise nia
February 8th, 2007 10:45 PM #25
thanks BoEinG_747!
pero panu pag new tires lang, like mine. bago lang un front wheels ko pero i can hear noise like it's sa bearing. i also doubt baka sa tires din un.
50-50 siguro na sa tires or sa bearing....
sa area ko ang dami choices ng emission testing. Bale 500pesos the lowest in my area. Sa iba nasa...
LTO accredited emission testing centers
