Results 1 to 20 of 20
    Sep 2006
    After Engine Wash at Petron Along Araneta Ave. near Banaue, i was on my to makati driving the long stretch of a.ave then suddenly my engine stop and produces no power, indicating Low Batt during a moving traffic near La Funeraria Paz. And so i pulled over to the street. F*c*ing S*** it's 9pm and nobody bothers to pull over and help. so i decided to leave and parked the car near the funeral home.
    Aday after i went back to look for a mechanic and told me that we have to replaced the "thing" (attached pic). that cost me around a thousand.
    Akala ko ok na... A month or so, problem occur, producing
    1. overheating (2x na nangyayari that it almost blow my engine)
    2. 10mins engine warmup will already indicate 50% at the engine temp. (noted that all fans works fine).
    3. Radiator sucks lots or even gallons of water on long drive.
    4. Leakage of engine oil on some part of the replaced "thing".
    5. Aircon Compressor starts to produce ethnic sound.
    Ive already replace the Aircon Compressor for the R134a freon. but iam not satisfied with the coolness tapos tinted windows/windshield, lalo na ngayong summer against the old compressor using R12, na kapag nagaircon ako kahit tirik ang araw sobrang lamig paren. Does anyone have a clue?
    Pinatingin ko ren radiator ko, and suggested by mechanic na ipaflushing daw, so i did.
    Yet iam still getting the same problem and continous spending is getting to no where.
    Tom, ipapaservice ko nanaman yung car for the leakage of engine oil.
    I badly needed some help here coz iam running out of money. Ive already thrown thousands. haaay... anyone who can help me solve this problems?
    Thanks...
    Jan 2004
    Are you losing oil AND water?
    The first overheating may have caused permanent damage already.
    Nagpa-comp test ka na ba? Anong kulay ng usok mo?
    Aug 2004
    Looks like an ignition coil or some kind of sensor... would be nice if you knew what it was.
    No doubt, those idiots who did the engine wash f***ed up your car. After that happened to me (long time ago... Sentra), I stopped having the engine washed outside the casa.
    eh yun kayang water pump mo oks pa kaya?
    May 2005
    Ignition coil nga iyan sa 1st pix..pwede din gamitin iyan sa MC ..ang mahal naman ata .250 Php lang iyan sa mga surplus shop ,kasi doon sa MC shop malapit sa amin 250 pesos benta nila ..ang bilis nga naubos
    Sounds like when they washed your engine, they didn't wait for the engine to cool down. Take one hot engine, add (relatively) cool water, and you have a prime candidate for a cracked block.
    Sep 2006
    Quote Originally Posted by the_wildthing View Post
    1. Yes. Radiator sucks alot of h2o even the reserve. ive already added coolant as i taught it would solve 1 of its problem pero nde paren.
    Losing oil is another issue. and the answer is yes. A guy from a geniune toyota distributor commented yesturday that, "it's possible, yung O-ring" that would cost me a very little amount arount 120 to 200 pesos plus 250 for the service charge.
    2. Permanent damage? balik ko po yung tanong... does this mean, once in a while i would be experiencing the high temp.?
    3. Comp. test?<---what do you mean?sorry idiot ko pagdating sa ganito.
    Kulay ng usok?<---none, even when i start pre-heat and step on the gas pedal in the morning, wala namang usok. although after 5 to 10mins pagpnakiramdaman ko yung buga ng tambucho, nakakapaso na.
    Sep 2006
    Quote Originally Posted by jaspi11 View Post
    ok naman sya. nagcicirculate naman. fans are also works fine. kaya ndi ko nga malaman kung san dinadala ng makina at radiator yung tubig.
    BTW whenever i drove for about 25km and then stop the engine for a while...
    my maririnig kang boiling sound from the reserve water.
    Then stable naman yung engine temp to 50% when driving.
    Sep 2006
    Well actually, that was the 1st thing that comes into my mind. Those service crew at petron doesn't know what they're doing. But what can i do dba. I can't ask them naman to shoulder the expenses.So natawa nalang ako sakanila. talking to myself "mga ugok yun. e-nengine wash nga... talagang pinaliguan pati loob ata ng makina inisprayan ng tubig " hahahaha
    Sep 2006
    Quote Originally Posted by ///MPower View Post
    hehehe... siguro nga ganon nangyari. kasi at that time after telling the crew na engine and body wash, umalis nako and i stayed at mocha blends and waited there until thier done. I forgot to check the crew men if he had covered the ignition coil and the alternator.
    Sep 2006
    Quote Originally Posted by BoEinG_747 View Post
    Oonga. Sat kasi yung namatayan ako ng makina. so following day sunday. most of the shops sarado. and at that time kase frustrated nako so kahit mahal binili ko na magstart lang ulit..
    oonga daw ang bilis maubos ng ganong part. 1st time plang kasing pinalitan chka galawin yung part na yun. tapos ayun na sunod sunod na sakit. pati ako napapaaray sa gastos. hehehe..
    Sep 2006
    Is buying a surplus radiator advisable? matapos lang prob ko sa radiator... every morning and afternoon kasi sangkatutak nilalagay ko na tubig.
    And dun sa overheating lets assume radiator is defective in terms of sucking lots of water yun lang. is there any possibility that since nagalaw yung ignition coil and nagcrack na yung "O-Ring", kaya sya nag overheat ng 1 last january and yung 2nd nito lang april?
    hirap ng tanga sa makina hehehe
    Radiators don't suck water. If a car is functioning properly, you won't have to replace it, as it's a closed system. Therefore, if you have to keep refilling it, this indicates that you have a leak. Since you also seem to have an oil leak, and issues with overheating, it's likely that your engine block is fractured.
    It could be that your radiator is cracked, and there's some sort of leak in the oil (two separate problems), but that's rather unlikely to happen together.
    I recommend you top up the fluids, park the car overnight, and check in the morning for puddles. If you have one puddle, you might have one giant engine issue. If there are two (one water, and one oil), then you have two smaller problems.
    check mo cylinder head gasket by openning you radiator cap while the engine is running and see if the coolant (water) forms bubbles, it means may leak sa water gallery holes to the compression chamber or WG to oil gallery holes.. madalas pag overheat yun C H gasket ang bumibigay. yup, it's the ignition coil. malamang mainit pa makina nun carwash kaya mapasma ito...hehe. sana di nag warp yun cylinderhead mo dahil sa overheat kundi mag papalit ka nito.
    Nov 2003
    maybe time to change mechanic...
    Sep 2006
    Leak from the distributor stops after changing the O-ring.
    BTW do you guys know any authorized dealer or distributor(Toyota) who sells parts for "engines "water pump" theres one kc in the merchant in the internet who sells it for about $70.42 around P3,000 to P3,600 here. pero d ko lam where to get one here in the metro.
    Apr 2005
    bro, there are a lot of auto supply stores selling toyota spare parts but don't just buy from any store. and hindi naman lahat ng parts kailangan original (otherwise sa casa ka bumili para sure oem). water pump? may replacement yan. we have fellow tsikoteers who have auto supply stores (i.e. G&S of glenster). PM mo lang sila or search some thread for details.
    May 2007
    Quote Originally Posted by cfatchma View Post
    I advise that you get an original GMB Japan water pump. It cost less than half than that of the original part and works and last as long as the original part.
    Call 743-4035 or drop by our shop at M7 Banawe.
    Jul 2006
    My thoughts exactly.
    When having an engine wash usually pinapalamig muna yan dahil mainit pa makina. These days aluminum heads can easily warp.
    Like mentioned have a compression test done. I do not know the actual figures for your car but somebody else might. See also if the water/coolant in your radiator is milky/viscous/malapot. Kung muddy yung itsura, baka nagmix na yung oil and water/coolant.
    Somebody asked about exhaust color dahil:
    Black - overfueling
    Blue - burning oil
    White - condensation or burning coolant/water (due to it mixing like mentioned above)
    Goodluck
    Nov 2003
    yeah gmb should be fine.
Badly needed some help
