Originally Posted by
dennis powell
tama si t2erns excessive differential backlash nga.it can be felt as well as you hear the clanks and its generally caused by loose parts striking each other,paadjust mo lang,and tungkol dun sa wheel play ng car mo,ano ba yun steering wheel? kung ito nga,hindi normal yan ,thats an excessive play,it should be 10 to 18 degrees or somtimes less,depends on your car,check mo yung steering linkage or tie rod ends could be damage,steering column U-joints and steering column bearings could also be damage,steering gear bolts might be loose,and steering gear could be worn or maladjusted.
