Results 11 to 18 of 18
- Nov 2006
- 299
January 15th, 2007 09:50 AM #11pag overly advance yung timing ng engine ay magdedesieling sya pero hindi ibig sabihin na di na nammatay(like diesel engine even if the key is off the engine still running but its just for a while then suddenly dies) ang problema ng kotse nyo ay maaaring isa sa mga ito,,,ignition switch,it might be corroded or loose,,,ignition relay,could be stuck closed.
January 15th, 2007 11:26 AM #12
- May 2004
- 302
January 15th, 2007 12:48 PM #13i also experienced this with my father-in-law SUV, ang main cause ay iyung aftermarket na alarm which have an automatic switch-on feature of the engine
January 15th, 2007 01:57 PM #14
January 18th, 2007 03:09 PM #15
nangyayari sa kin yan ngayon sa pajero ko. akala ko may problema na, turbo timer lang pala, after 1 minute pa sya namamatay
January 19th, 2007 09:25 AM #16
good day guys!
sorry ngayon lang ako nag-reply busy kasi itong week na to.
ok na yung sentra ko. sobrang advance pala ung timing kaya ayaw mamatay ng makina.
ang ginagawa ko nung ayaw mamatay disconect ko dun sa ignition coil kaya lng hassle talaga mag alis nun.hehehe. buti ok na sya.
thanks sa mga advice nyo.sa susunod uli!
January 19th, 2007 10:30 AM #17
Madalas yan kasi ang problema ng mga Gasoline Engine buti nabalik na sa normal. :fly:
January 21st, 2007 11:15 AM #18
Daming issue ng SU7:grin:
Xiaomi E-Car
