Results 1 to 10 of 18
January 12th, 2007 01:31 PM #1
good day guys.
help naman po sa problem na to.ano po kaya possible cause and ano dapat gawin? ayaw mamatay ng makina kahit naka turn off na ung ignition switch.
TIA!
January 12th, 2007 01:38 PM #2
1st gear mo tapos release mo yun clutch para magstall ang engine patay engine mo. ganyan din sakin dati yun may alarm siya.
January 12th, 2007 01:51 PM #3
How'd you turn it off to get on the net? Discon sa battery?
Malamang ignition switch ang problem... you might be able to find surplus assemblies in Banaue, pero I don't know how much.
January 12th, 2007 02:09 PM #4
forza1:
related ba sa alarm ung problem nung sayo sir?
niky:
una disconnect ko sa batt pero andar pa din. cguro dahil sa alternator. then after 2-3 mins kusa lng namatay ung makina.
January 12th, 2007 02:20 PM #5
Shock... big hassle yun.
Sa mga alarm, minsan may sariling cut-off at engine-start feature na umiikot sa ignition switch. Kung may aftermarket alarm ka, baka ito yung problema.
January 12th, 2007 05:22 PM #7
May kakilala akong killer, sureball yun, malinis tumira. Walang sabit at walang iniiwang ebidensya.
January 14th, 2007 12:37 AM #8
sana masolve nyo to, i have a friend kasi with the same problem, he has a daihatsu charade, it wont shutdown even with the ignition off, normally it happens pag na traffic sya, he has to run the car fast first to cool the engine down a little bit tas dun lang mamatay. he even had the car top-overhauled pero no effect, still wont shutdown. kindly post po pag na solve nyo ty ty
January 15th, 2007 08:25 AM #9
January 15th, 2007 08:32 AM #10
Maaaring masyadong naka advance yung timming kaya ayaw mamatay ganyan kasi pag sobrang advance. Pag switch off mo ba pumapalyapalya yung engine?
the triumph of man over... man!, using the crudest of implements (by modern standards).
Traffic!
